i will need to fix a large frame weighing around 50-60kg flush against a wall.
What would be the best fixings to use
MAny thanks
Michael
hanging fittings
Compomouldings
- Organisation: Compo mouldings ltd
- Interests: Framing
Re: hanging fittings
Wall anchors. They will vary depending on the type of wall the art is being installed on.
For the frame, the stronger the better for the hardware. Multi- screw metal plates with secure welded on rings (AKA "D" hooks) or bent plates with holes. Do not skimp on the quality or size of the screws.
Compomouldings
thank you all
Timh
Split batten would work as well if there's enough room in the rebate
