FRAMING WORKSHOP TABLES GUILLOTINE
davidcarter
Organisation: Carters Mounts
Interests: Painting, mountcutting.
Post by davidcarter »
With the sale of our Gunnar 601 Carters Mounts have x1 large 8 x 6 foot assembly table and x2 4 x 4 foot assembly tables solid joiner made assembly tables that need a good home. Bench heights are 39 inches so not back breakers. These have seen assemblies from everybody from the late Queen downwards . Location Cumbria. Seems a shame to put them in a skip at the end of the month if somebody could find a use. We also have a Lion supplied bench end guillotine for sale that fits on the end of the large one . Reasonable price.
David Carter
07795964234
KateD
Organisation: The Picture Framing Workshop
Interests: Picture framing
Re: FRAMING WORKSHOP TABLES GUILLOTINE
Post by KateD »
Hi i would like to buy the guillotine, give me a price you would take, Graham 07866843932
davidcarter
Hello Graham, you are more than welcome . £220 would do the trick if you are agreeable.
Many thanks
David
07795964234
KateD
Post by KateD »
Hi David have photo's that shows the model witch you have for sale as lion had 3x models over the years, thanks Graham.
davidcarter
Hello Graham,
yes I'll take some pictures when I get back to the workshops after 4pm today if thats OK. i'll also give you the measurement which I think of the top of my head is a 48 inch cut. I'll check and confirm everything anyway.
If it meets your requirments I can despatch by DHL ( our daily courier) on Friday to arrive Monday if you like. The 601, the photography kit and the top ten customer list are all attracting interest so Im trying to clear things effeciently and in a timely manner.
Many thanks Graham
07795964234
davidcarter
Hello Graham, pictures as requested. The foot pressing lever attachment piece from the middle of downward metal section is missing so Ive reduced tp £200 to allow for you to make a replacement with a spring attached to the floor. Ive put a metre rule against the assembly so its at least 36" cutting if not 40. Cuts 32" mountboard as standard.
This is heavy and definitely would require being bolted to the bench end but then you proberly know that.
David
07795964234
Abacus framing
Organisation: Abacus picture framing
Interests: Politics
Post by Abacus framing »
Hi David,
Late to the advert, has this been sold?
Regards
James
davidcarter
Morning James,
bench end guillotine still available and we could send by courier on Tuesday next week to arrive Wednesday if sale made . Useful bit of kit but as you have proberbly read once fixed to the bench end needs the last piece to fix the unit to the floor to engage the clamp down mechanism as the foot presses down. Easily fixed and the delivered price reflects that at £200. Cuts 32 inch mountboard easily
If you are interested please text in the first instance and we can go from there.
Hope that helps
David
07795964234
Abacus framing
Interests: Politics
Morning Davi
I'll take it, have just sent you a text message
Regards
James
davidcarter
SOLD NOW MANY THANKS
