If it's to glue two sheets of plastic, or correx together, I'd be inclined to use a contact adhesive.
You can get some easily at Screwfix.
Spread the glue evenly over each board, leave it to dry and then press both together.
A problem piece/home...
Re: A problem piece/home...
Thanks Dermot. Hot glue was going to be problematic with the size of it and it going off so quickly. I'll try that.
