Acrylic Expansion Gap
Anyone know the recommended expansion gap within the rebate for a 1.1m x1.7m frame using 5mm cast acrylic? The frame rebate is 7mm
Re: Acrylic Expansion Gap
Post by JFeig »
It depends on how much of a temperature change you are planning for.
The coefficient of thermal expansion for acrylic is approximately 0.075 mm per meter per degree Celsius (mm/m/K), which can vary slightly depending on the supplier.
This value indicates that a 1-meter acrylic panel will expand by about 1.5 mm when the temperature increases by 20°C.
Jerome, does that vary at all depending on the thickness of the acrylic?
Post by JFeig »
COF works in all directions at the same time. The thickness is of little or no concern.
Thanks that's really helpful.
