Carbon Fiber style moulding
Parm
- Organisation: Studios
- Interests: Classic car restoration
Hi All, A customer who is also a F1 fan wants a few A3 posters framed for his man cave. Ideally he wants a flat profile no wider than 25mm the style of the moulding to resemble black carbon fibre… Any help sourcing such a moulding (if it exists!) greatly appreciated. Thanks in advance!
Re: Carbon Fiber style moulding
I’m not aware of one but you could easily make your own, Google “carbon fibre wrap”.
Then a metallic grey mount and a deep bevel wrapped in the same stuff would look the biz!
Exactly..
You can buy self adhesive 25mm wide carbon fibre tape and stick it down onto some flat moulding.
https://www.amazon.co.uk/Spurtar-Air-Re ... 53f209f
Parm
Thank you . Ill give the wrap a try
- David
I've been wrapping ‘carbon’ frames for a long time. Get a vinyl that is intended for external use on cars, it’s generally guaranteed for 5 years. I have pieces I did over 10 years ago and they still look new. There are different finishes, I go for a matt 3D textured pattern. A tip when cutting the vinyl cut the short sides at 90 degrees to the long sides so the weave pattern is in the same direction. I also wrap each length before joining, folding the vinyl over the end of the moulding, this gives a cleaner more stable join. This does mean a weaker frame joint so I brace it with a 90 degree metal corner plate. If you want a really thin frame you can use an aluminium frame which takes the wrap well, otherwise anything with a smooth finish.
- David
This shows the 4 lengths wrapped before joining. This one is a grey 'carbon'. It also shows the different directions of the weave pattern.
- David
And a joined corner.
Parm
Gosh David, that’s super helpful, saved me a lot of trial & error. Thank you!
BaBaZa
- Interests: Pubs
Now available: https://mainlinemouldings.com/search.ph ... on%20fibre
Twitter #MainlinePolcore
Parm
Great, can you send a chevron sample?
BaBaZa
- Interests: Pubs
Certainly, please send and email to the sales team or complete the contact form: https://mainlinemouldings.com/contact-us/
