Packing Out Floating Frames
RobM
- Organisation: TBC
Could I ask how many of you pack out your floating frames, when the depth of the canvas being fitted is discernibly shallower than the moulding?
So I'm thinking of two ways (as attached photos, showing cross sections):
1. Pack out with foam core; or
2. Use an inner frame
Of course, the foam core would be the more straightforward option, but there's the added issue of getting fixings "through" the board. I guess it's the norm to just lay foam core strips in between to leave gaps for fixings, for this option?
The inner frame is certainly more professional, but of course more involved.
Are there any other ways?
Also, I was taught to leave a 5-10mm gap from the top of the canvas to the top of the moulding. Is the the norm, or do you use other dims (or even keep them flush)?
Thanks All.
Thanks All.
Re: Packing Out Floating Frames
I have never heard nor followed that rule. I have worked on "floater frames" where the are was above, even with, and below the top surface of the stretched art over the past 40+ years or so.RobM wrote: Mon 05 Oct, 2026 7:58 am
Regarding the use of a premilled moulding as a way of lifting/shimming the stretched art off of the base of the moulding, that seams to be a rather costly method of doing so, vs raw wood strips, metal washers, or sections of hollow tubing(or wood dowel) over a wood screw.
theframer
- Interests: football,fishing
I find a moulding that is the depth i need to raise the canvas and just cut 50mm strips placed where i screw it to the frame so only use about half a meter of moulding depending on how many screws are used.
Dave
www.iconframers.com/
Lions supply canvas offsets from 0-32mm in height.
RobM
- Organisation: TBC
Thanks Jerome for having responded to this one on two separate forums. You're right, I think I'm being overly precious about something that's generally quite straightforward. Washers are the way.
JFeig wrote: Mon 05 Oct, 2026 12:22 pm I have never heard nor followed that rule. I have worked on "floater frames" where the are was above, even with, and below the top surface of the stretched art over the past 40+ years or so.
RobM
- Organisation: TBC
This is very handy middle ground, saves greatly on a whole frame, thank you Dave.theframer wrote: Mon 05 Oct, 2026 1:56 pm I find a moulding that is the depth i need to raise the canvas and just cut 50mm strips placed where i screw it to the frame so only use about half a meter of moulding depending on how many screws are used.
RobM
- Organisation: TBC
You sound like a man fed up of my slew of basic questions
But the height of the clips isn't so much the issue, than the offset distance if fitting from the inner canvas to the inner of the frame, or am I missing something?
RobM
- Organisation: TBC
...unless I fasten them from back to back of course.RobM wrote: Mon 05 Oct, 2026 8:26 pm You sound like a man fed up of my slew of basic questionsDon't blame you.
I'll shut the door behind me...
No! I was just trying to give a quick answerRobM wrote: Mon 05 Oct, 2026 8:26 pm You sound like a man fed up of my slew of basic questionsDon't blame you.
A while ago I bought a little set of things for just this predicament but then couldn't find the right sized screws in time for the deadline, so they sit on my shelf of other interesting purchases, maybe one day I'll get to use them.
RobM
- Organisation: TBC
Hey, your suggestion actually got me right back on track to the easiest and most sensible solution. I have a tendency to get anxious about the elements I don't much experience in having done and was thinking I needed to pack out behind the canvas before even attaching the offset clips. A load of worry about nothing - attached a few 31mm offsets and the canvas sits perfectly level on them. The only packing out necessary was for the sides.Justintime wrote: Tue 06 Oct, 2026 9:55 am No! I was just trying to give a quick answerbut yes you're right. I can see how offsets wouldn't work. Theframer's answer sounds pretty sensible.
RobM
- Organisation: TBC
That looks exactly like a box of something I would acquire for one job, which would then hang around for years before further use.
It's funny the accessories we need to do some of this stuff. I was recently framing a vinyl record and just couldn't find a suitable spindle to fit through the centre hole to hold it in place. I'd only framed one record previously under the tutelage of Jeremy Anderson, so had to chase him to ask what we used that time: car clips. Perfect for holding up records.
Attaching a canvas to a floating frame was discussed a few months ago, on a post started by you.
viewtopic.php?p=162942
I normally offer the customer flush with the front of the frame, or below by 5 - 10mm and let them choose.
Why are you packing out the sides, surely the foamboard will be seen from the front?
We should start a gallery and swap shop! For all of the 100pc sets of incredibly useful fixings.RobM wrote: Thu 08 Oct, 2026 7:34 am That looks exactly like a box of something I would acquire for one job, which would then hang around for years before further use.
RobM
- Organisation: TBC
You're right, I have raised this one before. I'm getting a reputation as an abuser of the forum.pramsay13 wrote: Thu 08 Oct, 2026 7:43 am Attaching a canvas to a floating frame was discussed a few months ago, on a post started by you.
It seems like a narrow difference in the surface and frame is the norm, and between flush-10mm seems right.
