Mounting a colour print on - which board?
Starboard
Organisation: BabelOn-line
Interests: Photography, hopefully framing, and i make mean cocktails
Post by Starboard »
Hello,
I have two pieces of artwork, low value prints produced by an inkjet printer I guess (material is possibly PU? see picture).
Client is a pub owner who uses this purely as decoration, so we are not talking conservation here. He wants an acrylic glass in front to avoid any breakage issue.
The pictures (600x700mm) were both mounted with glue on foamboard that warped quite a bit. I was able to take the print off the foamboards easily.
Question is, what would you mount these prints on ?
I am not used to this type of prints. I normally make frames for paper artwork on a normal mount with T hinges and I use Art bak and Sekisui tape to protect the back.
What would you use to mount the prints on? Nubord? MDF ? Something else?
Thank you
Re: Mounting a colour print on - which board?
It does look plastic, it looks like a "print on canvas'. If it was me I'd first ask my supplier what self adhesive board they'd recommend for a plastic canvas print. Next I'd approach my local sign/banner maker graphics business. They'll have the materials and experience to do it, but in my experience the cost is surprisingly high but they use proper quality display board.
Alternatively if there's any/enough border left on the print, it could be stretched over strainer bars and glazed.
If it peeled right off the foam board it was probably mounted with spray mount which never gives a permanent adhesion.
