Keencut Help
Keencut Help
I've just purchased a second hand Keencut laser 1200 mountcutter my question is does the mountcard go face down on the board or face up when cutting Bevels and alike
If anyone could help me with an idiot guide or a book or some other guide on how to use this properly it would be very much apprieciated I have tried keencut but they no longer make the machine
Thanks all in advance
- SquareFrames
- Organisation: Dromore Picture Framing / Down School of
- Interests: Reading, relaxing, and funnily enough, its hard to stop thinking of framing
Keencut
Hi Darren,
A good robust machine you have bought, just make sure its clean, well lubricated, and it will give you excellent bevels and mounts.
Mounts are cut face down, so that the bevels are in the correct plain.
If you ring Keencut and ask for Andy or Alex, they may have a manual, their number is 01536 263158. I am not sure if you could download this from their site at http://www.keencut.co.uk
Hope this helps?
Steven
Hope this helps?
Steven
GCF Examination Centre
Re: Keencut Help
Hi DarrenDarren wrote:Hi
As with most manual mountcutting machines, you always work with the board face down when cutting the bevel. However, when you are squaring your board initially, work with it face up to ensure that it doesn't get dirty. Also, don't forget to use another piece of board (called a slip sheet) beneath the mountboard when you are cutting the bevel. This ensures that you get a good crisp cut with no fuzzy edges. You do not need a slip sheet for squaring board to size. Hope this helps.
Lyn
The Mad Mountcutter
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
We have used Keencut products for the last 20 years and have always found the staff to be very helpful. One of the very few companies in my experience who actually DO call you back if there is nobody available at the time to deal with your query.
Hi Lyn, welcome to the forum.
HOW Much!?
Keencut Help
Darren,
Sorry to be so late getting to the forum (there's a joke there somewhere!), as you have probably found out Keencut stop manufacturing spares 10 years after a machine goes out of production. The Laser has not been made for 13 years or so now. However, we do still have instruction manuals, bearings, knobs, screws, springs most of which are free of charge.
If we can be any help please ring on 01536 263158 or email on info@keencut.co.uk
And thankyou to the rest of you for your kind comments.
All the best
(KEENCUT)
All the best
(KEENCUT)
Andy Roberts
- John
- Site Admin
Hi Andy,
Many thanks for the information.
Could I suggest making this manual available as a downloadable pdf file from your website, if it is not already there.
A few months ago, being able to download the pdf manual for your oval cutter proved to be a real godsend.
HOW Much!?
On-line manuals
John,
Unfortunately the manuals we have for most of the very old machines are not good enough quality to scan and we do not have them in electronic format. The other thing is that we try and keep our website straight forward and if we to add manuals for all the obsolete machines as well as the current ones it could start to get a little cluttered.
I do take your point that it would be very convenient and I will look into the possibilities. We are in the process of completely re-designing our website so once that is finished in a few weeks time we can look at this as part of 'Stage 2'.
Regards
Regards
Andy Roberts
Andy,
I do not often use my Keencut oval mountcutter, but when I do there is one thing that irks me: Why are the measuring rulers on the table not 1:2 scale? It would make it so much easier to centre the blank prior to cutting.
Any chance of Keencut making sets of 1:2 scale rulers available for retro-fitting? I would be more than happy to pay for such an item.
Morso uses the same principal (but in reverse) when they incorporate a 2:1 scale to allow the framer to set double the moulding width without requiring him to remember his 'Two Times' tables.
In a way, Keencut is flattering the framer, obviously confident that most framers will find that division by two to be a trivial affair. However please note that, in the case of this framer at least, that confidence is totally unfounded.
(Sorry, John, should this have been a new topic?)
You will never get the last word on a belligerent buffoon
- John
- Site Admin
Seems like a good idea to me, More So. A perfect solution for the permanently bewildered, such as myself.
I could certainly use a set of those scales. Any chance, Andy?
HOW Much!?
