Morso servicing
rhiannon framing
Organisation: Rhiannon Framing
Interests: Framing, reading and being a mum of 3 keeps me fully occupied
Morso servicing
Post by rhiannon framing »
I need to get my Morso serviced. I am based in Kingston upon Thames - any suggestions
MITREMAN
Re: Morso servicing
Post by MITREMAN »
Hi Rhiannon Framing,
Ring Peter Stanlick At Framers Equipment
Tel 01604 790333
Mobile 07980660240
He will be able to help you, he can service,supplie all parts and sharpen your blades.
http://www.framersequipment.co.uk
Measure twice cut once. :lol:
Mitreman
MITREMAN
gesso
Organisation: The Gilders Studio
Interests: see above
Re: Morso servicing
Post by gesso »
Hi when you say servicing what does it need?
Mark Fisher
www.thegildersstudio.co.uk (Now Closed)
tel 07513605550
GL544DX
MITREMAN
Re: Morso servicing
Post by MITREMAN »
Keeping your machine clean, well oiled and the blades correctly fitted, sharpe and hollow ground with the correct draft on the left hand fence is important, always make a small test frame in a 3inch flat moulding after changing your blades with a postage size stamp whole, this will show up any adjustment needed in the left hand fence.
When cutting making sure you have your rebates supports are set correctly ( just kissing under the rebate not to high or to low )and the moulding is held tight and dose not rock, also if you do not use a Morso left hand support make sure that the moulding supporting bench is level with the machine.
You MITRE KNOWN that :giggle:
MITREMAN
MITREMAN
rhiannon framing
Re: Morso servicing
Thanks for all that. I am a new morso user and I've bought a neglected morso on ebay. I've changed the blades and given it a good clean but it is still not working well. I need someone to look at it and give it a bit of an overhaul.
Re: Morso servicing
rhiannon framing wrote: I am based in Kingston upon Thames - any suggestions
I'd say stay where you are - nice area - my daughter went to college there and her name's Rhiannon too!
