Hi Davie,
In my Tutor role I would always advise the use of glue on individual custom framing, the wedges/ nails are there to hold the frame together as well as support the glue while it dries.
Mouldings for hand finishing, such as staining can be a problem with glue you just have to be careful and don’t over glue and wipe away quickly any surplus.
Glue can also affect finishes removing colour and leaf on mouldings care is needed, so can backing tapes if allowed to stick on the outside of the frame.
Yes glue will rust wedges, moister in some timber will also, some wedges are treated to minimise rusting.
Cassese agents can provide stainless steel wedges mainly used for the window trade, this would avoid rusting problems.
As a Framer who has done may thousands of frames on productions runs, where the pictures are just a disposable decorative item, glue on certain section can be avoided
Speed is a must in this type of work, glue takes time to apply, and can glog up the underpinner distributor head and transfer onto the moulding from the back fences. When working in factories to these high production levels you don’t have time to F…
What I am trying to say is each type of frame job must be assessed (size, section, weight) safety of the artwork, the end user and your reputation are all at risk if you don’t.
So for custom frames I would glue.
Production frames depending on profile, speed needed and quality required
Yes you can get a rock solid joint without glue at the time of joining, but over time I would expect it to open.
MITREMAN
