making bricks from morso droppings
danchip1
- Organisation: Devon
- Interests: Doing the right thing
Cooking and eating curry
Ages ago i bought a gadget that u can crush newspaper in and making newspaper "bricks" to burn on the fire.
Has anyone ever tried putting, say, a weak mix of PVA and water with morso droppings and crushing them in said gadget, i guess it would have to dry in the crusher, or bond, if it does??
Experience welcomed, if not, i'll try it myself and report back!
thanks
thanks
Dermot
Re: making bricks from morso droppings
Why not make up a few moulds out of 4 x 2” timber that you can knock apart easily, them make a sludge of the chippings and the PVA solution and just pour it into the mould and let it go off over a few days.
Word of caution be careful of the fumes that the bricks (mixture of moulding finishes and the glue or either on their own) might give off, it could be carcinogenic….
- Bill Henry
We use Morsø shavings as kindling during the winter, although not in a “brick”. Because the mouldings are kiln dried, they burn hot and fast and will catch our fireplace logs in minutes.
The fumes from the shavings give me a blinding headache, but flames are reeeeal purdy.
Seriously, be careful if you are planning to use shavings from finished mouldings. The fumes, if not exactly toxic, can’t be good for you.
griff buch
- Organisation: Pheasant Framing
- Interests: Looking forward to retirement
weeding; washing the dishes
Scuba diving - Location: Sussex UK
... and they make a great bed of hot cinders in the bbq to put the charcoal on.Bill Henry wrote:We use Morsø shavings as kindling during the winter, although not in a “brick”. Because the mouldings are kiln dried, they burn hot and fast and will catch our fireplace logs in minutes.
...and don't forget to sweep the chimney.Dermot wrote:Word of caution be careful of the fumes that the bricks (mixture of moulding finishes and the glue or either on their own) might give off, it could be carcinogenic….
The Pheasant Plucker
There's no fool like an old fool
griff buch
and after you've cooked the food put more chipping on to help keep you warm after the sun's gone down.griff buch wrote:... and they make a great bed of hot cinders in the bbq to put the charcoal on.
- Bill Henry
Just be careful you don't wake up dead.
framejunkie
- Organisation: framejunkie
- Interests: 6.9%APR; 21.3%APR
I was looking into something similar to this. I live on a narrowboat so i keep warm in the winter by burning my off-cuts. I use unfinished mouldings almost exclusively so no major pollution issues. I use Morso pooh for kindling but it burns far too quickly to be useable all evening
My big idea was to buy one of those pneumatic log splitters and adapting it to produce large pellets. I don't like the idea of gluing the stuff together - its not exactly green to burn petrochemicals - unless you find some other way less polluting. But the commercial systems sold to large timber companies don't require glue - if you apply enough pressure it'll all stick together anyway
This is the type of thing i mean -
http://www.diytools.co.uk/diy/Main/sp-6 ... litter.asp
So far i haven't found the time or the money to start experimenting
danchip1
slightly disconcerting that there are topical ads in the box at the bottom of the page, my computer is intelligent!!!!
danchip1
oops, they apperared to have gone, did i imagine seeing adverts for paper and wood processing things? I've just worked a twelve hour day so it could be me...
WelshFramer
Well, there's always rabbit glue. I'm sure a local farmer would be delighted to provide some rabbits to add to the mix.framejunkie wrote:I don't like the idea of gluing the stuff together - its not exactly green to burn petrochemicals - unless you find some other way less polluting.
