John
With BBEST I no longer am able to download moulding descriptions from DJ Simons, is it my system or do DJ Simons no longer send them??
regards
Ian
description download missing
- Organisation: thought I was
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
Re: description download missing
Hi Ian,
The current D+J Simons table does have moulding descriptions.
To verify if this is the case, open notepad then drag the Simon's file (C:\Program Files\BBEst\Mouldings\si.csv) on to it.
What operating system (XP, Vista, etc.) are you using?
HOW Much!?
John,
Have uninstalled BBEST and then downloaded using the same info and key number as original, sytem comes back and says use code 1019, after downloading file, locating it and double clicking it asks to select prog to open with, it doesn't seem to want to load up.
Can you help please
Ian
Can you help please
Ian
- John
- Site Admin
The best way to proceed is by helpdesk hookup that will enable me to have remote access to your computer.
To arrangement for this, please call me (028 9024 7878) between 9:00am and 4:00pm
Many thanks - will ring later
Ian
Ian
PROBLEM SOLVED
Many thanks John, copied whole file from main comp onto a stick and downloaded onto the laptop.
Works fine.
Many thanks
Ian
Works fine.
Many thanks
Ian
