Question 1: How to you mount a photograph which has no border? I have been using the photo corners on others which works fine.
Question 2: I did a drawing for a friend about three years ago and did another one which she wanted the same moulding. She brought me the old one in to see moulding and the first thing I saw was that the drawing was cockled down one side. She had taken this to a local framer at the time. She asked me to open it up and see if I could fix it - yeh right! The drawing has been stuck down all over onto the backing board and taped over the front of the drawing along the top. The mount, backing board and glass were such a tight fit I had a struggle to get them out without damaging anything.
So the question is, how do I get the drawing off the backing board without damage and if this is possible can the drawing be 'uncockled'. I'm guessing no and no, but one can but hope!
It is bad enough to see such bad workmanship, but even worse, than 'a' I recommended this framer, and 'b' its my artwork.
Needless to say, I will be taking apart all the work that he did for me.
Thank you for your anticipated help once again.
