Second hand Pistorius
cmshand
Organisation: Home
Interests: All kinds of woodwork, cycling
Post by cmshand »
Hello there I am new to picture framing and have recently purchased on old pistorius underpinner. However it doesn't underpin very well, I suspect that a part is missing, the part used to guide the wedge into the wood.There is a guide which the wedges are pushed against, however there is nothing to hold the stack of wedges in place as the pressure is applied from underneath. I have included pictures to try and make more sense of my description. Does anyone know if instruction manuals are available? If so from where, and also, are spare parts are available? and if so, from where? Any advice is greatly appreciated.
Many thanks
Colin
countrystudio
Organisation: Bristol
Interests: framing
Re: Second hand Pistorius
Post by countrystudio »
Hello
The website for Pistorius underpinners is:
www.pistorius.com
Their e-mail is info@pistorius.com
They are still trading from Hauppauge, New York USA
Hope this is helpful
Regards
Heather
From this Grumble thread, it seems they have gone under.
http://www.thegrumble.com/showthread.ph ... s.../page4
Anyway, I'm not familiar with this machine at all, but in your photos I see a 'V' shaped block and a strip of wedges that should surely fit in to it, but they seem to be in the wrong way?
It might prove helpful to find out if any suppliers used to supply Pistorius underpinners in the UK. Who knows they may just have a manual and perhaps some spare parts still in stock.
Can anyone supply further information?
Ricky
Restoration.Horses.
Post by Ricky »
You would be right assuming a part is missing, Ive took the liberty of photo shopping your picture to give you an idea of what it should look like, I have a Pistorius but yours looks to be a slightly different model to mine, however the basics should be the same, the guide for the hammer is in two parts one of yours appears to be missing (see 1) number 2 is where the hammer comes through the side that is indicated is where the raised section of the hammer should be, thats the bit that pushes the wedge into the moulding
i hope this makes sense if not pm me your telephone & i'll talk you through it
cmshand
Organisation: Home
Post by cmshand »
Many thanks for all your replies, I have a clear picture of what I need to source now. Your picture explains everything perfectly Ricky
Colin
MITREMAN
Post by MITREMAN »
Hi cmshand,
Try my brother Peter at Framers Equipment Ltd.
He holds many spare parts for machines and can service and repair.
He often has Pistorius under pinners.
http://www.framersequipment.co.uk
Kind Regards
Mitreman :D
MITREMAN
