Cutting Wessex PW130
huntvambo
Organisation: Framed
Interests: Music, cycling, drinking, The Sensational Alex Harvey Band
Post by huntvambo »
DOH, should have checked the size before showing the customer :head:
Wessex PW130 plain wood moulding is 95mm wide back to front so about 10mm to wide for my Morso to cut :Slap:
Frame needs to be 55cm x 56cm, can anyone reasonably local to Alvechurch, Junction 2 M42, SW Birmingham cut this on a twin saw for me, please.
David McCormack
Organisation: Framing
Re: Cutting Wessex PW130
Post by David McCormack »
Have you tried completely removing the pedal stop bolt (if that's what it's called, see photo) and letting the pedal go up to max height? Could give you the 10mm you need. A bit of a fiddle to put back again but worth it if it gets the job out on time. :D
huntvambo
Post by huntvambo »
David McCormack wrote:Have you tried completely removing the pedal stop bolt
Hi David,
Thanks for the suggestion but I have already removed the pedal stop and put on my most worn blades, still need another ~10mm of travel :head:
Framerpicture
Organisation: Picture Framing
Post by Framerpicture »
Yo might find you can adjust the threaded bar that connects the foot pedal to the baldes to gain more travel
Vince442
Organisation: Alchemy Art & Framing Ltd
Interests: Art, photography, architecture, bonsai, travelling
Post by Vince442 »
A way of doing it without messing with the equipment is to do the first cut as far as you can. Then, where you cannot go any further that would be the face of the mitre. You should be able to bring down the blades and butt this face to the blades and continue to cut in this way all the way through the width of the moulding.
When doing the second cut you will have to take into account the extra distance you will need to allow for this method. This can be done in two ways. First, when you have gone as far as you can, measure the distance from the cut to the end of the moulding which you still have remaining; secondly, and the one I prefer, is to mark the actual distance you need the moulding length to be on the inside of the rebate. Then, align this with the bottom blade edge of the morso and do the cut. Then use this as the face of the mitre butting it up to the blades each cut.
huntvambo
Post by huntvambo »
Thanks Vince,
Obvious really, uses a bit more moulding but does the job.
Vince's method is one I have used before. When you have gone as far as poss, you can go sideways to nibble off the waste on the left side to balance the cut a bit. If you remove the rebate supports (you can get away with this on bigger mouldings), you can cut mouldings up to about 4.25".
Post by Graysalchemy »
if you were near madchester I would cut it for you no problem.
