Good evening - not posted on here recently but here goes.....
I need 10 mounts cut to 35"x35" (overall size) with a 5" border (4 sides). Obviously this requires jumbo board and as Lion don't like to send out these sizes I'm somewhat stuck. One way would be to get them cut to size and bevelled as this greatly reduces the size for transit.
Do any of you know of anyone in the Bristol / Cirencester / Stroud area who may have such a stock holding or the ability to cut the mounts?
Many thanks.
The mounts need to be white.
Jumbo Mountboard
- Jonny2morsos
Re: Jumbo Mountboard
Colourmount list Bristol Framing Supplies as one of their distributors.
You should get a deal on a pck of ten I would have thought then its just a matter of trimming 25" of the long side and 5" of the short. This will leave you with some useful sized off cuts as well as ten 25" x 25" fall outs.
- Tudor Rose
Have you tried contacting Wessex? They will cut mounts to size for you and deliver - so it might be worth giving them a ring.
I know it's no help at this time, but when I get my new CMC, I could help you out in the future, as I'm in Bath.
Steve
Steve
Arqadia will post you 2 packs of 5.
- Framerpicture
Try Kev on this forum (www.frames.uk.com) he's cut Jumbo mounts for me before
- Organisation: Apollo Framing
- Interests: Travel and New Zealand art
I'm fairly new to the Bath area but I've got a Zund M1600 computerised mount cutter and I can cut jumbo boards for you with no problem up to a thickness of 4.1mm.
Check out my webpage (www.apolloframing.com) and please get in touch if interested.
Regards
Paul at Apollo Framing
Regards
Hi Paul,
Welcome to the forum mate.
See you later
See you later
