Framing medals - correct method of attaching ribbons
I've been thinking of doing a medals case display in the shop window using replica medals. These replica medals come supplied with 6 inches of ribbon which you have fit yourself.
Can anyone give any advice about the correct way to do this in particular:
1. The correct length of ribbon to be showing.
2. How to attach if the medal only comes with a small round ring to attach the ribbon to. I've seen medals with the ribbon folded and fitted through the ring, but can't remember how it was done.
3. Should the ribbon always be attached to a broach-bar at the top?, or if it is only for framing, (i.e. not to be worn), is it customary to omit the broach-bar?
Thanks,
Mark
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
Hi Mark
I have completed quite a few Military medal display boxes.
To me there is a difference between a Military/Campaign medal and other awards like sports or achievements.
To try and answer your questions though.
1. I always mount military medals on a brooch bar. This way they can be easily taken out for cleaning or for wearing and then replaced.
2. From the top of the ribbon to the bottom of the medal should measure 95mm.
3. Where a ribbon enters a closed ring then the folds should be 45 degs either side. This takes a bit of careful folding and very careful use of a steam iron and pressing cloth.
4. There are 2 ways to mount medals a) Swing Mount - where they can swing freely but also lay flat. The normal way. b) Court Mount - where they are sewn onto a backing type plate with the same ribbon as a backing. Normally for Royalty or for High Ceremonial occassions.
5. Please make sure that the order of precedence is correct.
See the following link for that
http://www.medals.org.uk/united-kingdom ... ibbons.htm
Hope that helps you.
John GCF
John,
Thanks for the info - Most helpful.
Mark
John,
I assume that medal ribbons are made to a standard width. Any chance of telling me what that might be?
Thanks,
Mark
Merlin
Interests: Aviation
Post by Merlin »
Mark
Not all ribbons are the same width unfortunately..
They are supposed to be 32mm wide as the standard. I have one that is 34mm wide yet others that are 33mm.
I would work on 32mm if you want to make 'slits' in the mount instead of using a brooch.
John GCF
Thanks John,
No, it's not for making slits in the mountboard, but for helping me make a spreadsheet for medal case dimensions and prices.
I am gradually coming up with spreadsheets and worksheets for every task we are likely to undertake. In the longer term, it will enable me to delegate more of the work to my staff, both in the workshop and when serving customers.
