Gloss finish swept frame
CalicoFraming
Organisation: Calico Framing
Interests: Picture framing, fine art
Post by CalicoFraming »
Hi all,
I urgently need to source a white swept frame, the more elaborate the better. Thing is it has to be a glossy finish.
Know thee of such a thing?
many thanks
Calico
Framerpicture
Organisation: Picture Framing
Re: Gloss finish swept frame
Post by Framerpicture »
Check out Arqadia- They have white swept frames http://www.arqadia.co.uk/vcat11/#/293
CalicoFraming
Thanks, I just spoke to them and they've got some crazy designs, but they say the finish isn't glossy which is what my customer is demanding
Post by Graysalchemy »
Tin of gloss spray paint. If you are careful you can get quite a good finish. I have done a large pink one for a client :giggle:
You can get things quite glossy if you buff them up with wax and a yellow duster.
If you want the really 'wet look' gloss, see above. :P You might have to build up a few coats.
Jonny2morsos
Post by Jonny2morsos »
There is a high street chain of ladies wear shops that has glossy white frames as part of its current window display. Looks quite impressive until you get up close and see they are thin moulded plastic. Fooled me at first glance!
standenfineart
Organisation: Private
Interests: Private
Post by standenfineart »
Another option is to finish with a clear coat high gloss Nitrocellulose lacquer obtainable from luthier supplies as an aerosol or in cans.
BUT BUT BUT pre-check on a spare piece for solvent action on the painted under-finish.
CalicoFraming
That's a whole heap of great advice, thanks everyone
Ricky
Restoration.Horses.
Post by Ricky »
Frintons do a nice range in Gesso you can finish yourself. :D
