Bosuns Pipe and Medals
mikeysaling
Post by mikeysaling »
By mikeysaling at 2012-03-24
Medals NATO former Yugoslavia; RN Meritorious Service; RN Long Service + bar for additional 15 years.
I used econospace to give extra depth to the frame for the court mounted medals : The 'bulb' of the pipe rests in a similar size hole in the backing board and velveteen.
countrystudio
Organisation: Bristol
Interests: framing
Re: Bosuns Pipe and Medals
Post by countrystudio »
Very nice job indeed.
Heather
Hi Mickey,
Another excellent medal framing job as per your usual high standard. Your work shows that you have a real passion for what you do. :clap: :clap: :clap:
retropic
Organisation: Frames
Interests: Frames
Post by retropic »
That looks great. I like that it doesn't look overcrowded and I like the velvet background. A very smart composition.
I was experimenting in the workshop with some box frame we had lying around and decided to do something with my Dad's police and army memorabilia which were lying around in drawers. The constraints were that the box frame was just some black stuff we were using regularly; the police helmet rose was quite deep and I didn't know how best to mount the medals (I have discovered that they flap around in the frame when it's moved, so this is not ideal); I've only been framing for around six months and I can take it apart and do it again now I know it's not quite right (after all they are my bits of memorabilia, not a customers). I also don't like that I used a blob of glue to hold the whistle on and the cut of the aperture is a bit ragged.
If you don't mind me hijacking your thread, I'd be grateful for thoughts and ideas on how I could improve on this and what I could do differently. How for example could I invisibly secure those medals?
Bit of a rubbish picture I'm afraid. Am still mastering the art of taking photos of frames without getting glare (have followed the threads about that on here and the solution seems very complex).
IFGL
Post by IFGL »
Wire or fishing line aronud the base of each medal going through a pin hole in the backing, will stop them swinging.
Melinex/mylar straps also would, but unlike wire is clear and unlike fishing line, is flat and unlike either, can be more securely fixed - no knots.
They can be cut as wide or as thin as you like, so would also work for the whistle, and its chain.
IFGL
Post by IFGL »
I will try Melinex/mylar straps on my next medal job, I have not seen these before nice tip.
