bendy MDF
CalicoFraming
Organisation: Calico Framing
Interests: Picture framing, fine art
bendy MDF
Post by CalicoFraming »
I have a painting done on one of those prepared canvas covered artists boards which was quite bowed in each direction, so glued it onto a sheet of 6mm MDF to straighten it out. Seemed good at first, but now the MDF seems to have bowed along with the painting.
any suggestions on how I can remedy this situation and also perhaps how I could have approached it better in the first place?
many thanks
Calico
Jonny2morsos
Re: bendy MDF
Post by Jonny2morsos »
I think I would have put the MDF behind the board in the frame without glueing the two together. This assumes you are using a normal frame and not one of those L shaped tray mouldings.
Re: bendy MDF
Which way has it bowed?
You can sometimes rectify a bend by painting the back with and heavy coat of acrylic paint, although I doubt it would work fully on 6mm stuff.
CalicoFraming
Re: bendy MDF
Ah yes, should have said - I am using an L shape moulding :wink:
