Deep frame with matching spacer
Does anyone do a deep frame with a matching spacer. I've seen the Arken ones in the Lion catalogue, but I'm needing some that will be a bit deeper, possibly around 3 inches or more.
Re: Deep frame with matching spacer
A 3" rebate is pushing it, but a matching spacer as well is probably OOTQ! You'd probably have to adapt/fashion something.
Don't think you'll find what you want in finished stuff, but Rose&Hollis do some very deep box moulding in plain obeche if you fancy a bit of painting.
A333 has a rebate depth of 80mm. complimentety spacer 65mm. But you can get extra bits to extend this to 120mm with 103mm spacer.
