hello!
Say hello, and tell us a little about yourself.
mark cagney 29
Organisation: mc framing
Interests: golf
hello!
Post by mark cagney 29 »
hi,, i am new to this forum, im irish and have recently taken up picture framing on the side. :)
i have a problem though , i bought a morso f and it cuts perfectly until i go to join the four sides
together and there are gaps on the inside of each mitre. so it would appear my morso is cutting
mitres at 46ish degrees instead of 45. can someone help me as i am in fear i have bought a dud :(
easypopsgcf
Organisation: home
Interests: cars
Re: hello!
Post by easypopsgcf »
Welcome along, It won't be a dud so don't worry about that. Left fence probably needs a slight adjustment.
I think it is , Gap at front=move fence towards you, Gap at back = move fence away from you
It could well be the other way, as it's only something i've read as mine works perfectly :D
Also how are your blades, sharp?, hollow ground?
There was a good article on Morso servicing on here recently, worth a read if you can find it
JohnMcafee
Organisation: Scenes
Interests: Picture Framing
Putting the world to rights
Re: hello!
Post by JohnMcafee »
Welcome aboard, Mark.
Rest assured that there is nothing wrong with the geometry of your machine. If you search the forum you will find that this topic has been discussed several times here in the past.
Your problem is caused by movement of the moulding as it is being cut. If you can prevent this movement by tightly holding the moulding on the left hand side as you bring the blade down, particularly on that crucial final cut, you should see a big improvement. On the other hand you could follow the advice of many framers by just compensating for the movement by setting the left fence back towards you a tad. However, note that the amount of correction to be applied in this way depends on the width and hardness of the moulding.
Re: hello!
Hi and Welcome Mark. :D
What the last two said. :lol:
Wood is funny stuff and it's not exactly consistent. You will probably find this problem gets worse as the blades slowly lose their edge. If you are cutting wideish moulding then the gap will get multiplied because the diverging angle. Use very fine adjustments on the left fence. If you start to get a gap on the outside then you have gone too far.
Jonny2morsos
Re: hello!
Post by Jonny2morsos »
You can downlaod the Morso manual here:http://www.lionpic.co.uk/media/242807/m ... list_f.pdf
Section E-3 describes fence adjustment.
Re: hello!
Welcome to the forum, we now have a Mark Cagney as well as a Mark Lacey :clap:
mark cagney 29
Interests: golf
Re: hello!
thanks people. i look forward to trying tomorrow if ye're expert advice works ! :lol: :lol:
names within frames
Organisation: Names Within Frames
Re: hello!
Post by names within frames »
And a big welcome from a relative newbie too :)
Vince442
Organisation: Alchemy Art & Framing Ltd
Interests: Art, photography, architecture, bonsai, travelling
Re: hello!
Post by Vince442 »
Hi Mark and welcome!
I was watching an episode of Burn Notice a few weeks back and it had both Sharon Gless and Tyne Daly in it. :D
mark cagney 29
Interests: golf
Re: hello!
also.
if i decide to get my blades resharpened , how much would it cost? and where would i get it done, and i would like a good job done, not the shitty ones i have heard so much about. im in limerick in rep of ireland.
philipsheldon
Organisation: Ashworth & Thompson Ltd
Interests: JUDO / NFFC / CRICKET / REAL ALE ...oh, and Life in general.
Re: hello!
Post by philipsheldon »
:D Afternoon,
Welcome the Forum. Ashworth & Thompson offer a blade sharpening service from the Belfast branch.
Let us know if this appeals.
with kind regards,
Phil Sheldon. 00 44 115 964 7507.
There's nothing I can do if it don't get through, blame it on the Pony Express !
There's nothing I can say if it's gone a stray, blame it on the Pony Express !
mark cagney 29
Interests: golf
Re: hello!
i appreciate your help regarding getting my blades sharpened, but as i am down the south of ireland would i not be a bit far away from ye?
regards
mark :)
Re: hello!
Post them. :D Maybe costs a bit in postage, but that's life.
If you deal with A&T then maybe the rep could visit and take back the blunt blades.
Beware general sharpening services. It's not worth saving a few yoyos. Morso blades need specialist sharpening. :P
stcstc
Re: hello!
Post by stcstc »
i get mine sharpened by amd in dublin, they send them to a place in dublin who specialise in it
and amd just collect them and drop them back, might cost a little more but no grief :-)
mark cagney 29
Interests: golf
Re: hello!
cool thanks guys. might try amd first so as they are nearer. :)
