mylar encapsulated double sided
stcstc
customer brought 2 of these things back from india, wanted to be able to see both sides
encapsulated them in mylar then framed with trucolour glass both sides
Re: mylar encapsulated double sided
Nice work Steve.
Just got myself some Mylar.
Mylar, speciality glass, rag mountboard what is happening to me
Now where did I put my masking tape
Did a couple of old maps recently. Also double-sided. And also with the edges showing. I sandwiched the two pieces of glass with p-90 and made a thin insert at the back held in with spring clips. That way you can quickly flip the contents around to show the other side.
stcstc
jeez alistair you will be turning into a bespoke framer!!!!
ah you just cant see the masking tape on that one
Been doing museum work recently and a large exhibition all in hand finished frames, so still contract but more discerning.
- IFGL
Quote STCSTC ' and more beer tokens'
That is the plan
That is the plan
Nice job Stephen!
I like using mylar in framing as well. It's so versatile, very easy to work with and it's not just for conservation framing jobs, but it can make life easier when framing so many PITA jobs.
