Moulding needed
pramsay13
Moulding needed
Post by pramsay13 »
I'm needing a deep unfinished moulding, width 20-30mm with a rebate depth of at least 46mm as I need clearance of 40mm.
This one from Arqadia :132400000 is ideal, but won't be in for around 3 weeks.
Any ideas?
IFGL
Re: Moulding needed
Post by IFGL »
Simons do one very similar .
pramsay13
Re: Moulding needed
Post by pramsay13 »
Thanks IFGL.
I haven't used simons before an the website doesn't seem the flashiest :o
Do you have a code?
stcstc
Re: Moulding needed
Post by stcstc »
lion do one too, again cant remember code
Abacus
Re: Moulding needed
Post by Abacus »
A42 obeche from rose & hollis looks the same to me.
easypopsgcf
Organisation: home
Interests: cars
Re: Moulding needed
Post by easypopsgcf »
Holroyds in Glasgow do one H590raw
pramsay13
Re: Moulding needed
Post by pramsay13 »
Thanks easypops, the ones I looked at in Holroyd weren't deep enough. Do you know how deep that one is?
easypopsgcf
Organisation: home
Interests: cars
Re: Moulding needed
Not exactly off the top of my head, I'm sure I have a bit in the workshop, I'll measure it in the morning and let you know :D
Re: Moulding needed
Rose&Hollis do a really deep one - A333. About 80mm deep rebate. If that isn't deep enough there is a complementary extender that adds another 40mm or so. And matching spacers to boot. :D
easypopsgcf
Organisation: home
Interests: cars
Re: Moulding needed
Ok,
There are 2 quite similar. H595raw and H590raw, not sure which is which, but a quick call to them and you'd know.
One is 19mm wide with a rebate depth of 36mm, the other which is very close to what you need is 24mm wide with a rebate depth of 43mm
HTH
Re: Moulding needed
Post by Graysalchemy »
Simons OBEC/0025 :D
Timh
Re: Moulding needed
Post by Timh »
let me know if you get stuck
I have obeche in stock and could run a couple of lengths and have out to you for early next week
can run any square moulding very easily to any spec wanted.
