Wanted: Drumstick Display Frame
GenestealerUK
Organisation: Just me
Interests: Drums, Grunge Music
Post by GenestealerUK »
Hi guys, I am after a custom 3d memorabilia frame designed to hold 2 drumsticks horizontally. The drumsticks are 17 inches in length and the frame would need to be black with a wide white mount and a black internal background
Similar in design to this image (but with the white mount as described above)
An inner smaller mount as below would also be preferred
Are their any framers that can assist me with this?
pramsay13
Re: Wanted: Drumstick Display Frame
Post by pramsay13 »
I'm sure most of the framers on here could help you with this.
Where are you and I'm sure there will be one reasonably local to you that would be happy to oblige in exchange for some of your paper money?
GenestealerUK
Sorry yeah of course...
I am in SE London/North Kent area.
Kwik Picture Framing
Interests: Picture framing
where these drumsticks framed locally from where you are?.
GenestealerUK
No the guy that did these lives in the US and doesn't do international exports.. plus this is designed for 16 inch sticks. Hence why I need a local UK framer to make one for me
Have you tried yell.com. Best to look on there, quite few framers where you are?
GenestealerUK
Am I to assume from you suggesting yell.com that this is something any framer can do? That I do not need to find a specialist?
It's not a difficult job, any decent framer should be able to provide what you want.
IFGL
Post by IFGL »
I would think any framer on here should find this a fairly simple job, just make sure who ever you use will use reversible methods to hold them in place, like mylar straps.
.. and don't take any stick!
True, take them sticks to your local framer, and show them the photo.The framers can make to measure and fit into the frame professionally
pramsay13
Post by pramsay13 »
It's not particularly specialist although I have never framed a set of drum-sticks.
It's a box frame, which can be used for all manner of objects, I've framed a wine cork, car reg. plate, xbox game cases, baby-gro, football cap, etc.
Most bespoke framers will be able to do it, as said just check how they will be hanging the sticks. You don't want to find out in 20 years that there is a wood screw through the back into the middle of your stick.
GenestealerUK
Thanks for your help guys. I shall just take them to a nearby framer. :)
