The problem I am having is something I have noticed happening more so when I have used the wider deeper mouldings but is still apparent with the narrower ones. This is that slight gaps are noticeable at the back of the joint. With the deeper mouldings this is more of an annoyance as it is more noticeable to the point where I have felt it necessary to fill the gaps. These spaces can tend to double up for the last joint.
When I first got the underpinner I wondered if the gaps were due to the wedges being designed to force the visible front joint together which caused the slight opening at the back. This didn’t really make sense to me so I decided to check out the angle on the mitre trimmer. I did this by using a set square by pressing against the blade whilst bringing the frame guide up to it firmly and then tightening the fixing nut.
Having done all this and still having the problem I am now puzzled and hoping someone might be able to cast some light on the most likely cause.
I do try to hold the moulding firmly whilst trimming the edges after rough cutting the mitre by saw. The only other thing I can think of is that the blade needs sharpening though it does seem as sharp as when I bought it. Thanks.
Steve.
