Storing finished frames
dandydon07
Organisation: AF1
Interests: golf and football
Post by dandydon07 »
Looking for some advice/thoughts.
How do you guys store your completed frames? I currently have a bench in the front shop that I have completed frames stored under....but it's obviously of a certain size so can't get any frames larger than 80cm high or 60cm wide to fit.
I therefore just have these frames sitting around the front shop....making it look really busy (which is good) but really untidy..... And leaving the opportunity of getting damaged.
Do any of you have made to measure racking shelves or do you just do the same as me and have them sitting in the shop? Okay I appreciate some of you may have a larger back shop so you can store them there but any info and/or pictures would be great.
Ian
Re: Storing finished frames
Sometimes I hang them on the wall if they are a bit special (and I have a gap).
I do have a handy under-the-stairs cupboard, but that's mostly full up with assorted kelter.
Abacus
Post by Abacus »
I have a purpose built racking system. 75 cubby holes, 3 x 25 small, 3 x 25 medium and 3 x 25 large (and deep). These are made to store the frames vertically. For each size (small, medium to large) there are a three different widths, again small medium and large. They are made from mdf and they are stacked, the large and deep at the bottom, medium in the middle and small on top. The cubby holes have felt on the bottom to stop any damage.
Each cubby usually holds one customers' jobs, unless obviously it's a large job which can overflow to other cubbies.
They are numbered and we keep a list. When we put a frame in the rack we enter the number on the list with the customers name. When they collect we scrub the name.
(We also have an overflow rack of a further 26 odd shaped cubby holes a-z, (currently all 75 and a-j are occupied! Woo hoo)
dandydon07
Organisation: AF1
Thanks guys,
Would love to see a photo or two of your made to measure units abacus if you could possibly post them?
You can email me at icraik27@hotmail.com if its easier but I'm sure other framers would like to see your handy work.
Thanks again
Post by Graysalchemy »
I have palette racking. and i also have an old glass crate which is handy. :D
Abacus
Post by Abacus »
I'll take some pictures on Monday and stick them here.
You won't stick them, you'll attach them in the proper manner - OK!
Abacus
Post by Abacus »
I'm not in the fatg anymore, so I can stick them however I like!
pramsay13
Post by pramsay13 »
I'll tell you where you can stick them. :sweating:
Abacus
Post by Abacus »
A picture of our storage rack, the bottom hutches are 36" tall and 30" deep, middle are 28" tall and 20" deep, top ones are 22" high, 20" deep.
The slots are mainly 3" wide with 4 of each size at 6" wide.
the slots have felt bases.
pramsay13
Post by pramsay13 »
Ooh very neat Abacus. Do you not wrap your frames once they are finished?
dandydon07
Organisation: AF1
Thanks abacus,
Very neat indeed.
Gives me food for thought....oh did I mention food! This diet is an absolute nightmare!!!haha
Will let you know how I get on,
Kwik Picture Framing
Interests: Picture framing
Very nice Abacus. We got storage similar underneath the order table. For bigger picture frames we have upstairs storage room.
Abacus
Post by Abacus »
We wrap the frames after the customer has ok'd them. Otherwise we'd have to wrap them and then unwrap them to show the customer, is that what you do?
pramsay13
Post by pramsay13 »
I wrap them with handywrap stuff so when I show them I just peel a bit back. I would end up with scores and scuffs all over mine before the customers get them as I don't have such a neat storage system.
All mine are wrapped in bubble wrap, much better protection than handy wrap
Bubblewrap is great. I tape it with masking tape which is easy to peel off to show the customer the frame.
Steve N wrote All mine are wrapped in bubble wrap, much better protection than handy wrap
That is very true but many commercial clients want corners and handy wrap so they can see the image without unwrapping and re wrapping.
Better still is bubble wrap and the Blue Foam corners. :D
