Morso F problem
Iain
Organisation: hobbyist
Interests: picture framing
Morso F problem
Post by Iain »
I have got my Morso F with the blades stuck in the closed position. The handle which adjusts the amount taken off with each chop is fully to the right. How do I open the blades or move the handle left to open the blades? Thanks
Re: Morso F problem
Sounds like the linkage has come adrift somehow. Have a look underneath.
Welcome to the Forum btw. 8)
Iain
Re: Morso F problem
Post by Iain »
Thanks. No the linkage looks OK it is just that the blade block will not move backwards.
Iain
Re: Morso F problem
Post by Iain »
Sorry also it might be that the packaging/security pin has broken off in the whole. How long should it be. Mine is about 40mm but one end has a funny shape!
pramsay13
Re: Morso F problem
Post by pramsay13 »
Can you post some pics? I'm not sure I understand the question.
Re: Morso F problem
Is this the first time you have used the Morso? If so then maybe it's just a case of not realising that the handle has to be depressed to disengage the ratchet teeth before being pulled back towards you.
