Multi ap platform mount
This is the back of the mount - looking at an under-mount but with 90 degree cut apertures half a mil larger than the cards. Pasted to the back of the multi-aperture mount with freshly nuked starch paste. The paste goes RIGHT to the edge of each 90 degree cut aperture (dark board) Cards simply dropped in once dry.
platform multi.JPG (111.36 KiB) Viewed 40228 times
Fall outs placed back in
platform multi 2.JPG (129.48 KiB) Viewed 40228 times
and taped over the corners with gummed linen tape
platform multi3.JPG (101.38 KiB) Viewed 40228 times
Front - doesn't look any different to how it would if they were hinged or stuck down - but no adhesive whatsoever and a piece of cake with a CMC - tricky without one, but do-able.
platform multi 4.JPG (130.42 KiB) Viewed 40228 times
Abacus
Re: Multi ap platform mount
Post by Abacus »
:clap: :ninja:
IFGL
Post by IFGL »
Nice job sir, we have been using this method since you posted a how to a while ago, the last time was on Saturday, it has become one of our standard methods of attaching a picture.
Elite
Organisation: Elite Medals & Framing
Interests: Military medals & history, Framing (of course),Rifle shooting (F Class competition).
Post by Elite »
Very nice Roboframer. Is it necessary to secure the two mountboards together before putting the cards in? :)
Absolutely - and right up to the apertures too, to prevent the cards (or whatever) slipping between front and back apertures. The two mounts are one.
Kwik Picture Framing
Interests: Picture framing
Ill try that next time
Elite
Post by Elite »
Roboframer wrote:Absolutely - and right up to the apertures too, to prevent the cards (or whatever) slipping between front and back apertures. The two mounts are one.
Excellent. Thanks for that.
Kwik Picture Framing wrote:Ill try that next time
Almost a year, Kwik - 'next time' must have surely happened! How did it go?
233ART
Organisation: ART233, GALLERY/FRAME SHOP
Interests: COLLECTING & RESTORING OLD TOYS...
Post by 233ART »
Nice one Robo...
girlfromkent
Organisation: Creative Frames
Post by girlfromkent »
Hi and a thank you to Roboframer for imparting this knowledge; I too have used this method several times for photos and it works a dream.
I'm just about to use it for some art on thin paper though and I'm thinking that for security I might hinge the pieces to the fall outs, before refitting them into the slots, so there's no chance of them moving about.
Can anyone see why this might be a bad idea?
Post by JKX »
Multi aperture like this?
If so I don’t think it necessary unless it’s extremely light tissue paper and even then, probably ok if they are small
It’s two mounting methods, if hinged you don’t need the platform mount and vice-versa, but if it is multi aperture the platform mount will save having to position each item.
Nothing wrong with the idea though, unless hinges could be seen through the paper.
The “soft platform” mount may be an alternative too.
https://www.thegrumble.com/threads/new- ... que.86870/
