Hi All, any help here would be greatly received. I have been framing for a few years now and most of my range of mouldings are small and stretch up to approx 50mm max. I have been asked to make a frame for someone who wants to use a larger moulding which measures 75mm from front to back and the rear height is 45mm. I have tried a test cut on the Morso and it is 5mm too short to cut the moulding, the blades don’t go high enough.
Basically my question is can you raise the blades/cutting head on the Morso?
Ash
Morso Height Adjustment
Ash the Framer
- Organisation: The Framing Factory
- Interests: framing
easypopsgcf
- Organisation: home
- Interests: cars
Re: Morso Height Adjustment
Yes , if you look over the top of the cutting head you'll see a fixed rod going down to the pedal mechanism, it's got a bolt either side, loosen the top one and then ajust the bottom one, then re tighten the top one
If it's just a small extra bit of hight you need to gain, take off the pedal stop. Hook your toes under the pedal and push it up. Might just do it.
Abacus
is it available on chop? (or have you already bought the moulding, if so, sorry, not very helpful)
Ash the Framer
Thanks all, will try the above and report back
