Wizard 8000 stops mid cut
stcstc
Re: Wizard 8000 stops mid cut
just looked at those numbers again
they dont make sense
Total Corners:
0339988
Total Mat Cut:
0023407
means average of 14.5 corners per mount, he he
maybe there is something else that makes it make sense
Total Corners:
0339988
Total Mat Cut:
0023407
Kwik Picture Framing
- Interests: Picture framing
Lets see what yours says
Maybe it's to do with the machine cutting the outside as well as the inside? I only get it to do both on two occasions I can think of, when the offcuts on a single mount would be no use and when the machine, due to the clamps, would produce less mounts from a board than if I cut the outsides manually.
- JohnMcafee
- Organisation: EstLite
Curves count as multiple corners.
A circle might count as 10 corners, I don't remember the exact figure.
Also some mounts will have multiple apertures.
stcstc
57014 mount mine
in just under 4 years
so 14253 a year average
Abacus
An answer and a question:
I've just fired up my 800 and cut the following:
1) Double mount cutting just the two apertures
2) Single mount cutting inside and outside
Statistics:
Number of corners 16
Number of mats 3
(so the number of corners is correct, 8 for the double mount and 8 for the single mount)
But... why are my stats resetting every time I boot the PC?
(P.S. the "stopping mid cut" seems to have gone away after I disconnected and reconnected the media cable)
Statistics:
Number of mats 3
Check your licence details? That's what I did
Sam Cook
- Organisation: Framers Corner
- Interests: .
Hi Guys
I know I'm a bit late to this discussion but just to clarify your Wizard corner count:
When you look at the licence it will show you the 'Current Corners' ie the corners for the design you have ready to cut, and this will reset for each new design. However the 'Total Corners Used' and 'Total Mats Cut' will be a continuous count (or basically as long as your PC hard drive doesn't fall over!).
Each corner is counted with each blade plunge, so if you cut a rectangular opening and an outside then that is 8 plunges. Like John said there will be more corners in multi opening mounts and v grooves, stepped corners etc (ovals and circles are counted as 4 plunges.)
Hope that all makes a bit more sense.
Sam
Sam
