Simons Pine 26
Hi John,
I've not tried it yet, but it should be possible to make your own coloured wax using the appropiate powdered pigment and neutral wax. I already got a 500 gram tub of Venetian red (which looks like terracotta), so I better buy a mortar and pestel, so I can give it a try.
I have been known to make my own paints and glazes using powder pigments and a suitable binder, so I have a little tip to share.
A small amount of Iso-propanol alchohol added to the pigment will stop the stuff flying around in the air while you're trying to mix it with whatever you are using as a binder.
I have tried tinted waxes in the past, but I found them rather hard work as you tend to get too much wax on and it can get a bit messy. I find it quicker to apply clear wax with a stiff paintbrush, working it well into the grain. (bit of white spirit makes it flow better in cold temps). Then wipe off any excess with a rag, but don't buff. Leave for about an hour and lightly dust over with dry pigment (or rottenstone) with a soft brush. A little goes a long way so no need to splash it on all over Then get a nice yellow duster and buff it up.
Good method for bleached wood is to just give it a wash over with diluted white paint (artists arylic or just matt vinyl). Wipe off with a paper towel and let dry. It's particually effective on oak and ash as it just needs a light waxing to finish. Obeche really needs a sealing coat. Decorators varnishing wax is good as it does not yellow the the finish.
