Garage Workshop
avantime
Post by avantime »
[img]desktop/workshop[/img]
avantime
Post by avantime »
Thought I'd put up a picture of the workshop. The framing area is over near the clock and the moulder can be seen centre left. We also have the glass cutting area in another unit.
The Crofter
Interests: Photography
Post by The Crofter »
Big picture, 736Kb and I have to scroll on my 24" monitor !!
Some garage :)
Pat
So - here it is 800x600 - now then - what's that blue thingy on the right with the sloped thingys coming from it?
(Hey - getting pretty nifty on the old Irfanview ain't I!)
avantime
Post by avantime »
That's a panel clamp - we glue strips of oak together before sanding to make panels to make furniture. There is an oak sideboard you can see in the foreground.
avantime
Post by avantime »
Thankyou for re sizing my piccy by the way!
Looks like a noisy sort of place - most noise my place makes, unless I cut myself or something is "THUNK-PSSSST"
avantime
Post by avantime »
Roboframer wrote:Looks like a noisy sort of place - most noise my place makes, unless I cut myself or something is "THUNK-PSSSST"
WHAT?!!! You'll have to type louder! :D
osgood
Post by osgood »
Roboframer wrote: what's that blue thingy on the right with the sloped thingys coming from it?
John,
It's quite obvious that is a rocket launcher thingy, for instant delivery of finished frames.
Sheeeeesh..............do you have to have everything explained to you??? :wink: :wink:
Moglet
Organisation: An Urban Myth
Post by Moglet »
More cool workshops. This has got to be the best Forum Show 'n' Tell to date! 8)
Envious of the beautiful Aussie sunshine streaming through your windows, Marky! :D
........Áine JGF SGF FTB
vfmarky
Post by vfmarky »
Hi Aine, We're having a lovely but dry Autumn here. This thread is great.
I see that a lot of you folk have your Fletcher type mat cutters mounted up right. Is that to save space?
If you're not living on the edge, you're taking up too much space...
Hey Avantime. How did you get a pic of my kitchen? :shock:
The Crofter
vfmarky,
Yep, saves space and also makes for a very comfortable working position.
Pat
avantime
Post by avantime »
prospero wrote:Hey Avantime. How did you get a pic of my kitchen? :shock:
I've been stalking you! :D
vfmarky
Angling the mat cutter
Post by vfmarky »
Hey Pat, I had an idea for mounting Fletch at an adjustable angle. With the advent of CAD in drawing offices, there are loads of those old style drawing tables around. They're adjustable for height as well as angle. Hmmm, might investigate...
The Crofter
Mine is secured using cable ties, brackets & wire. Only a temporary measure of course, one day I will make proper fittings :wink:
The cutter is also supported at the back around half way up, this should reduce any bending stress and most of the cutting is done in the lower section.
Pat
