The brown gum tape on a frame I made has dried out and come unstuck. What do you think? Too little wetting? Too much maybe? The way I do it is I have a soaked washing up sponge on a plate and I run it along the length of the tape. It's wet, with a couple of drips falling off, and seems pretty sticky.
Any ideas?
Thanks!
gum tape coming lose
Re: gum tape coming lose
There are some mouldings it just won't stick to. Sanding the back of the moulding a bit sometimes fixes it.
- Interests: Pubs
A few framers have said they put a little bit of PVA glue into the water.
Twitter #MainlinePolcore
- StevenG
prospero wrote:There are some mouldings it just won't stick to. Sanding the back of the moulding a bit sometimes fixes it.
Hmmm, learnt that the hard way - sanding seems to work though.
- Jonny2morsos
Does not stick to synthetic mouldings you need self adhesive for that and as Prospero says some finished wood moulding may need a light sanding.
