How to protect pure gesso finish?
Posted: Sat 18 May, 2013 10:19 am
by jmdwilson
Just wondering amongst you hand finishers how you leave frames which are just pure gesso?
I usually leave them uncoated after having sanded then polish to smooth finish BUT feel they need a coat of something on them...
Have tried wax but leaves streaky marks.
Any suggestions?
Thanks for your advice.
James
Re: How to protect pure gesso finish?
Posted: Sat 18 May, 2013 11:13 am
Gesso has a porous surface - the better to take finishes. But left raw it will absorb all the airborne pollutants not to mention fingermarks and such and soon look manky. It needs sealing with something. You could paint it with white acrylic (Might need to mix up the right tone as Titanium white is brighter than the gesso shade). Or you could try spraying with satin picture varnish.
Posted: Sat 18 May, 2013 11:20 am
by jmdwilson
Thanks prospero
I have tried acrylic paint on top but it looses the marble like finish and only possible to achieve complete smoothness by spraying not brushing.
The idea of satin varnish I like & will experiment with.
So right it does pick up finger marks and stains easily.
Posted: Sat 18 May, 2013 1:57 pm
by Framerpicture
Posted: Sat 18 May, 2013 2:11 pm
by jmdwilson
Have always wondered what the Renaissance wax could be used for (I have seen it in Lions catalogue also).
Just wondering what makes it different from Liberon wax which seems to leave residue & streaking.
Will order some on my next order Monday.
Thanks again for the suggestions
Posted: Wed 05 Jun, 2013 9:48 pm
by CalicoFraming
Rabbit skin glue size
Posted: Fri 07 Jun, 2013 4:28 pm
by jmdwilson
Thanks David - have experimented since my posting and will try rabbit skin size next - sounds so simple.
thanks again
Posted: Wed 19 Jun, 2013 12:25 pm
by CalicoFraming
Would be interested to know how you get on with this.
Posted: Sat 02 Jul, 2016 10:00 am
by GeoSpectrum
Sorry to bump an old thread but I've been experimenting with spraying ripple paint with good results but I'm wondering if it needs sealing? If so what would be the recommended sealant? I've got a very nice smooth marble finish with the ripple paint after a gentle sand and a polish with a clean cloth so would want to preserve it. I know traditional gesso is porus so will pick up dirty etc but not sure about the ripple paint?
Posted: Sat 02 Jul, 2016 3:00 pm
Bit of clear wax. Sorted.
You could give it a coat of this if you want it a bit tougher. Comes in Satin and Gloss as well.
Posted: Sat 02 Jul, 2016 4:37 pm
by GeoSpectrum
Thanks wax it is. I might try spraying the varnish though as I seem to be spraying everything else....
Posted: Sun 03 Jul, 2016 11:17 am
I'm thinking off building a conservatory onto the shed. Spraying for the use of.
Posted: Sun 03 Jul, 2016 6:57 pm
by Graysalchemy
Why not just build and shed instead of a conservatory for a shed
Posted: Mon 04 Jul, 2016 2:52 am
What build a shed onto the existing shed? That would be an extension.
