CCA Galleries?
iamzero
- Organisation: From home
- Interests: Art and music.
CCA Galleries?
Just bought a secondary market print by Peter Blake that has been framed by CCA Galleries in a white box frame with tiny spacers. I need to open this up to reframe as to be honest its not up to my standards, any idea what I might find in there? Has anyone has any dealings with them?
Many thanks.
Many thanks.
Kwik Picture Framing
- Interests: Picture framing
Re: CCA Galleries?
Hi have you tried your local framing shops, See what they offer you in terms of just re-framing
iamzero
Re: CCA Galleries?
Thanks for the reply fella but I do intend on framing this myself of course? Already framed 3 Blakes previously that cost more than I paid off of my mortgage last year. Just curious to see if any other framers had any previous with CCA?
Re: CCA Galleries?
I've dealt with CCA but only ever bought the prints only, nothing mounted or framed. I'd guess they'd mount things as per most/all publishers - badly! If floated, double sided tape or possibly rolled up self adhesive tape. But maybe if it's something close framed with a spacer and no mount it won't be fixed with anything at all.
I've got an idea - open it up and see
iamzero
Re: CCA Galleries?
Thanks Robo dude,
spot on guess fella... no mount and right up to the tiny spacers. I'll open it up next week when I've decided how to reframe but the suspense is killing me in the meantime as to how they've fixed it, hopefully not at all. I'll post a picture from my iphone when I get chance.
Re: CCA Galleries?
Nah probably used carpet tape or if they had pushed the boat out it may be drymounted onto the backing board
iamzero
Re: CCA Galleries?
NOOOOOOOOOOOO!!!"!!!!!!!!"""!!""!!!Graysalchemy wrote:Nah probably used carpet tape or if they had pushed the boat out it may be drymounted onto the backing board![]()
iamzero
Re: CCA Galleries?
Just out of interest, what do you think they use for spacers on this method? If I'm float mounting a piece then I use painted wooden spacers which is fine because they don't actually touch the artwork but with these spacers they rest on the artwork all the way around. So if I wanted to recreate this look to conservation standard obviously the spacers I use can't physically come into contact with the art and making up spacers from cotton rag is time consuming, any suggestions?
Re: CCA Galleries?
Why not take the frame apart
iamzero
Re: CCA Galleries?
Purely because I frame from home and am lacking in time and space right now. I've picked up so much work lately from friends and family it's a little overwhelming. Getting stuff from friends of friends now so stacked.
Re: CCA Galleries?
Well I wouldn't worry about it
until you are ready to refame the work then
Abacus
Re: CCA Galleries?
I'd probably use econospace from lion, seems pretty inert.
Re: CCA Galleries?
Set a shop up, Then you can have the complete framing workshopiamzero wrote:Purely because I frame from home and am lacking in time and space right now. I've picked up so much work lately from friends and family it's a little overwhelming. Getting stuff from friends of friends now so stacked.
iamzero
- IFGL
Re: CCA Galleries?
zest it works well on 7-70 tape pretty much the same as using water on starch glues.
iamzero
Re: CCA Galleries?
Thanks for the comment dude, picked some up yesterday so will give it a go later.
Re: CCA Galleries?
Why not just run a blade down the middle of the tape and leave it on the back?
I'd be worried about tearing the artwork.
iamzero
Re: CCA Galleries?
Because this is my person print and don't like the idea of the devils tape across the back of it. If it belonged to a customer I'd be tempted to do as you've suggested though.
Abacus
Re: CCA Galleries?
What damage do you think the ph7-70 will do to the print in the future?
