Blades ripping moulding
Trinity
Any thoughts on this please, morso blades just ravage this soft pine moulding. The blades in the morso were cutting ok but nevertheless I changed for a newly sharpened (LIon) set, but the blades seem to tear the wood out of the mitre and chip the back. Both sets cut harder mouldings fine.
Is there a knack, is it likely to be the moulding, any ideas please
Keith
Keith
Re: Blades ripping moulding
Is the wood soft and spongy? if so that is your problem IMHO, I used to use a cheap aqadia moulding which was like that had to switch to a plastic in the end until a few years ago when they realised the cheap Chinese carp was no good.
Trinity
Internally it is Grays, soft without much by way of composition.
I believe the technical term is 'snotwood'.
Trinity
Tell you what it's a never to be repeated pita, it'll take some explaining.
easypopsgcf
- Organisation: home
- Interests: cars
Mmmmm Weetabix
- IFGL
I think you have been extremely lucky to have not come across this rubbish wood before, just get a credit on the stuff and bin it.
Trinity
"Mudda Fada kindly disregard this letta" (sort of)
You might know the song if your as old as --him over there.
Stick 3 and 4 were ok and the job was completed late last night, I'll see what response I get from my mate behind the counter. You can absorb a lot of stuff though if the end result is good.
This same internal mess can also sometimes be seen in foam center board where the foam core has degraded.
Yup sometimes seems to be a bad stick or two in with the rest. Seems to be the finish is the only thing holding it all together. As others have said you just need to bin that lot and get a refund.
Trinity
Prospero - obeche, stained pine,sorry for the confusion.
- IFGL
if you don't ask for a refund on the dodgy stuff the supplier won't know there is a problem that needs addressing.
