Cassese underpinner - standard of underpinning
TinaB
- Organisation: Tina Bailey Framing
- Interests: Photography, theatre, dancing, reading.
Hello again all,
Please see the attached photo. Can I have your comments please on the location of these wedges? Would you say this is acceptable or not!?!
Many thanks,
Tina
Many thanks,
Tina
Re: Cassese underpinner - standard of underpinning
I'm not sure that how it looks will matter, especially as you will be covering most if not all of them with tape.
The question is whether the join is secure and will remain sound for as long as the frame is in use. I'm not convinced that a join with off-centre wedges will be as good as one with the wedges in the right position.
I'd be looking to get it sorted and get everything aligned. I don't use a Cassese so I can't help with what to check.
- David McCormack
- Organisation: Framing
It's not right, they should be in the center.... no reason for them not to be bang in the middle. Must be the right back fence that's out?
easypopsgcf
- Organisation: home
- Interests: cars
Which model of underpinner is it, there are quite a few cassese's available, i'm sure once you post the model, someone who has one/used one will help, also maybe a couple of pictures from above so we can see whats happening?
TinaB
Hi guys,
Many thanks for this. I bought this Cassese CART new from one of the main framing suppliers. They continue to state that this is correct, i.e. that the wedges should insert off-centre of the joining line. Incredible! I may be relatively new to framing but I know what the desired result should be (and so do they)! Not happy to say the least that they are trying to state that this machine is working correctly. It's obvious that it's off-centre as you can see from the photo below.
It's nice to have some other opinions on the matter for moral support!
Take care and happy framing!!!
Tina
Tina
TinaB
And you can see it here too...
Thanks for giving me peace of mind!
easypopsgcf
- Interests: cars
Mmmm, I'm not familiar with the CART model, but I'd say 100% that there is no way that's right. Did you get the manual with it? There is usually an exploded diagram, which should help you loosen the appropriate screws/bolts to centre the firing mechanism, possibly the 2 recessed allan bolts either side of it .
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Hi Tina
No the underpinner is not right do not attempt any adjustments of your underpinner as this could affect your warranty, contact your supplier for them to rectify.
Mark
Mark
- David McCormack
I have the older CS88, it looks like you have one of the newer models. Looking at this page from the user manual downloaded from their website, what they are calling the 'Wedge Distributor Block' is clearly centered and yours is clearly not!
If they are telling you that then they are talking twaddle. This is completely unacceptable on a new (and not inexpensive) machine. Tell them in no uncertain terms that you either want it fixed pronto or a replacement machine.TinaB wrote:Hi guys,
It's nice to have some other opinions on the matter for moral support!![]()
Tina
As Mark T says, don't fiddle around trying to fix it. They have sold you a lemon so up to them to make it right.
I wonder if you were speaking to the right person at your supplier, I think that you need to contact them again and make sure that you are talking to someone who knows what they are talking about. I own and use a CS-88 and I can tell you beyond any doubt that the alignment of the distributor block in your picture is definately not correct and that a main framing supplier should know this.TinaB wrote: I bought this Cassese CART new from one of the main framing suppliers. They continue to state that this is correct, i.e. that the wedges should insert off-centre of the joining line.
To tell you otherwise is obviously not correct! Particularly since such a degree of misalignment could be a very serious issue when joining very mouldings where there is often little margin for error in placing the wedges and not being able to place the wedge in the same position in both pieces being joined could make producing a satisfactory joint almost an impossibility, if there is little or no margin for compromise!
I think that this machine Is currently not fit for purpose and requires corrective action to resolve this issue!
easypopsgcf
- Interests: cars
My bad for suggesting you should fix it yourself, its just that is what i would do, as i assume (wrongly sometimes) that i am as capale as anyone else to fix anything
Send the suppliers MD a link to this thread and tell him/her they are lucky you've not named and shamed them..........yet
TinaB
Thanks so much for your help everyone. It is much appreciated!!!
I was as sure as I could be that it was wrong but when you get a professional person who has been in the framing business for many, many years (and is with a big framing company) telling you that it should pin off-centre you begin to question yourself (when new to the business).
Sadly this has not been the only problem though. Add clearly reground rusty blades being presented to me under the guise of new blades (for the Morso), confirmation phonecalls not received as promised, failure to respond to most of my emails, cancellation of visits on the morning they were due (or one person not turning up meaning work halted), and visits to my home where little was accomplished, I have given up in despair. The lying has been the hardest to deal with though. Very disappointing!
I find myself in the situation of still being without an underpinner that works correctly, and an Excalibur 5000 still in its box awaiting installation, 1 month (less 2 days) after they were delivered to me. VERY frustrating when I just want to get started!
Needless to say I have returned the Cassese, the Excalibur is pending collection, and I want as little as possible to do with this company in the future. It has been one long stressful and frustrating exercise. I just don't understand how companies remain in business when they act this way.
Thanks again for all your help and support everyone. Onwards and upwards!!!
Happy framing,
Tina
Happy framing,
Tina
iamzero
- Organisation: From home
- Interests: Art and music.
I'm amazed with your ability to not name and shame the company that told you that those wedges should be off centre? That just not acceptable.
TinaB
Many thanks to Phil at Ashworth & Thompson for all your invaluable help today! I was very impressed with your standard of service. Thanks also for spending so much time discussing mouldings with me!
I am pleased to report that I am the happy owner of a shiny new Cassese courtesy of Phil, and I am over the moon to say it works like a dream
I can finally start framing!!!! No more of this...
and more of this...
Break out the Bolly...
Take care all.
Tina
Take care all.
Tina
Pleased to hear you are sorted Tina.
It probably won't be the last problem you'll have, but rest assured that whatever sprags you get someone here will have had the same one at some time and know how to fix it.
TinaB
You're so right, I thought as soon as I pressed 'submit' that I should have reworded it 'fewer problems' rather than 'no problems'. That's life as they say
I am so grateful for this forum. It's nice to know so many people in the trade are willing to provide help to us newbies!
Best wishes to all,
Tina
Best wishes to all,
Tina
