World Cup Postcards
Nige Hogg
Organisation: NH Framing
Interests: Sport, Reading and 70s music
World Cup Postcards
Post by Nige Hogg »
I framed a set of World Cup Postcards from 1930 to 2010, with a view to selling it at the Saltaire Craft Fair. I sold it quite quickly. A lady asked me if I could make one for her. Because the 1942 and 1946 world cups were not played, due obviously to the second world war, I had left a gap between the 1938 and 1950 postcards on the first frame. The lady asked if she could design a postcard for the 1942 and 1946 years. She designed the post card and I framed it with the others. I thought she did a good job and it gave the frame an impact. It shows a bayonet going through a football.
The frame isn't warped it is just my unprofessional photography.
pramsay13
Re: World Cup Postcards
Post by pramsay13 »
Sounds like a great idea Nige. Any chance of a bigger picture?
Nige Hogg
Post by Nige Hogg »
Try this one.
Is it a printed sheet or individual postcards; if individual, how are they mounted?
Nige Hogg
Post by Nige Hogg »
They are individual postcards. I think the term maybe 'float mounted'. I cut 21 apertures out of the mountboard, 5mm smaller than the postcards on each side and taped the post cards (3 small strips per edge) to the cut out board. Each individual card was then sunk back into it's corresponding aperture and taped on the back to secure. The postcards differed in size to each other by a couple of mm, so it was difficult to have them all lined up exactly.
Smiffy
Organisation: Frame
Interests: Wood, glass & v-nails
Post by Smiffy »
We use the same method for Papyrus...
Nige Hogg wrote: ..... I think the term maybe 'float mounted'. I cut 21 apertures out of the mountboard, 5mm smaller than the postcards on each side and taped the post cards (3 small strips per edge) to the cut out board. Each individual card was then sunk back into it's corresponding aperture.
I'm not getting it, if the apertures are smaller than the postcards how can they be 'sunk' in to those apertures?
Float mounting means mounting to see the edges of the paper/whatever.
David McCormack
Organisation: Framing
Post by David McCormack »
The edges of the postcards are showing. I think he has been describing the hedgehog mounting method :)
Aha! So, the 'cut out board' would be the fallouts and then they are put back in to their apertures with the cards mounted to them. :idea:
Nige Hogg
Post by Nige Hogg »
Apologies for my lack of knowledge regarding terminology, but I live and learn.
I now know what the 'Hedgehog' technique is.
I should have described the cut out board as the 'fall out'
Was I correct in saying that it was float mounted'? :oops:
David McCormack
Yep to float mounted. If you can see the edges it's floated and if raised (on top of something like 5mm foamboard) it's called a pedestal mount. Nice job BTW :D
Nige Hogg
Post by Nige Hogg »
Thanks David
