Afternoon all,
Ok, we're having some issues with our Morso. It has a pair of newly sharpened (genuine) blades on, which are both sat on the machine flush, and pass through the fence enough to give a clean cut on the back edge.
We're cutting an oak moulding, which we use regularly and have no problems with. However, since we have these blades on, the problem has started.
When cutting this moulding (Arqadia 114 200 000), which is pretty hard going, the motion of pressing the pedal down appears to be 'spongy' on the last cut, making it difficult to press the pedal all the way home. Once the wood is cut and we're onto the pinner, we're being met with a nice gap at the sight edge side of about 1-1.5mm.
I know that the usual issue causing gaps is the rebate support position, but they are both sat in the correctly.
I think this spongy feeling on the last cut is causing the problem, I just cant diagnose it!
Any ideas?
Morso Cutting Problem
- YPF
Re: Morso Cutting Problem
I always cut this moulding upside down - it removes any issues with rebate supports.
- Organisation: York Framing Studio
- Interests: Photography & Astronomy
I always cut this one upside down, not sure if that will help but worth a go?
Steve
Steve
- Organisation: Frame
- Interests: Wood, glass & v-nails
Cheers Gents, cutting upside down on this is certainly a better way of doing it (fuming that I hadn't realised that before having to be told!). Seems to have taken the sponginess away too... Only thing left to ask, when cutting it upside down, I'm still being left with a minor gap on the inside of the mitre - any way of preventing?
Thanks again!
Thanks again!
- Organisation: Framers service
- Interests: Reading, computer software and hardware.
Customer Service
Is the tooth on your ratchet handle worn?.
Other thing to check is wether the travel on the blades is set too low.
This is adjusted on the two nuts on the long connecting rod at the back of the machine. It connects to the y upside down y piece.
Hey David - how are you?
The teeth and arm are both less than 12 months old, and as such are pretty immaculate.
I think I've found the problem with regards to the 'spongy' feeling on the last and second to last cuts... It seems we have been treated to our blades being flat ground opposed to hollow. I've never cut with flat ground blades before, and to be honest didn't even consider the grinding might have be.
See attached photo of simple experiment! Left side mitre cut with flat ground blades, right side mitre cut with (blunt-ish) hollow ground blades. Amazing.
- image.jpg (2.57 MiB) Viewed 2729 times
