I have a customer who has bought a few original pieces from us has asked if I can reframe one of their existing pieces as it looks a bit stale now. They would like the piece to have a small frame to cover the edges as there a couple of areas of damage, and this mounted on a white back with 50mm boarders and this then framed with a white moulding.
The piece measures 910 x 590 mm.
My provisional plan is to use a small plain wood moulding (painted white) to frame the piece, this will be then fixed to a white back (marine ply???) and to use the Lion 47mm 'Bare Wood Cubik L' Ayous
again painted white.
Would be most grateful for input, and marks out of 10 for the idea!! I have seen this sort of thing in Galleries but have not had to work out how it is done as my wife prefers her canvases in tray frames.
Forget the plywood back.
Do the inner small frame as you suggest, then make a frame from a 2" flat moulding or even just a ordinary bit of square wood. Fix the small frame to this and fix the whole lot inside an outer frame.
Simples.
If the painting is a bit thin and wappy, put a backing board behind it and slap it in.
Sounds like a Nicholson frame to me, sometimes known as a St Ives frame. Very popular in the South West
Hopefully this link will work http://theframersforum.com/viewtopic.ph ... n&start=20 but if not just search Nicholson frame in the Forum search function and the thread will come up in the results. Plenty of info and photos of examples on there.
They can look fantastic but make sure you charge a sensible amount for your time on this one as the painting and fitting together can all add up.
Forum Moderator & Framing Educator www.pictureframingtraining.com
I'd use this as an opportunity to sell some posh glass (yes, this has glass in) - but not just for the sake of upgrading the sale. If it's glazed it'll never need cleaning again and you can then use more readily available and easier-to-cut materials, like normal mount board bonded to whatever your default backing is; some matching (or contrasting) rebate spacers and you're away. Might not cost that much more actually - might take less time???
