i've found one that looks promising through yahoo stores, awaiting a response
basically, the customer loves this picture so much, (no accounting for taste) but the copy they had was drymounted onto MDF, and is basically, ruined, - showing a lot of the characteristics that you'd expect from acid damage.
i promised i would try and source a new one for them, but so far it is proving a bit of a Pain.
The Ebay print does not have the title of the print on it, that where the size differance comes in.
The image must be the same size. If the Yahoo Stores does not work. Then the Ebay one would if you cut a mount with a title box and add in the name.
Either way your customer will get the print.
