absolute framing
Posts: 278 Joined: Mon 03 Oct, 2005 11:19 pm
Organisation: Absolute Framing
Interests: Reading the Lion Catalogue
Post
by absolute framing » Sat 09 May, 2015 11:40 am
The clamps on my 299 are engaging as soon as i turn on the Machine.
They are normally in neutral and only engage when either the foot-peddle is engaged or the Clamp Positioning button is turned to on.
There is a video below to Illustrate the problem
Any Help/Advice would be much appreciated
Stephen Strahan
absolute framing
Post
by absolute framing » Sat 09 May, 2015 11:59 am
I have a feeling the issue lies in here
SOMEWHERE.....
Stephen Strahan
absolute framing
Post
by absolute framing » Sat 09 May, 2015 12:57 pm
So using a bit of intuition and gut instinct I felt the issued lied around the clear tube going into the foot peddle (4)
Started by taking off external cover
Then carefully removed top with suitable allen key - To find this
So I put the broken spring back in, just put smaller bit down bottom and inverted longer piece and re-assembled.
I'ts now all working properly again, however don't see spring lasting.
Anybody out there sell this part ?
Stephen Strahan
Posts: 11620 Joined: Tue 05 Jun, 2007 4:16 pm
Post
by prospero » Sat 09 May, 2015 1:11 pm
Not sure, but I'd guess that that spring is maybe not specially made for that machine. Lots of springs available online so it's a question of some careful measuring and finding one the right size.
A few here to choose from....
http://www.entexstocksprings.co.uk/inde ... 35&unit=mm
absolute framing
Post
by absolute framing » Sat 09 May, 2015 1:24 pm
Thanks Prospero,
Was thinking the same thing, local hardware only has 6mm x 25 mm
Need 5mm x 25 mm to fit into hole
Stephen Strahan
