Limits of CNC Mount Cutting/Etching/Bevel etc
IPFraming
Organisation: Inner Piece Framing
Interests: Small Framing and Gallery business in Berkshire. Bespoke framing mostly to artists from southern UK.
Post by IPFraming »
Hi all,
New to the business so please bear with my newby status.
Am trying to find out about what is possible with today's CNC mount cutting technology. I have seen a lovely mount of the SAS on the web and am looking at finding out how/where to get something similar done with Royal Navy Wings motif. Reasonably complex design.
Could you please advise of your collective knowledge as to the possibilities today and maybe point me in the right direction?
Seb
PS: Avatar is my wife, far better looking than I and besides, she owns the business!
Belinda Sheppard
Inner Piece Framing
The Berkshire Gallery
Lower Way, Thatcham, Berkshire. RG19 3TL
http://www.ipframing.com/
Tel: 07806 56 33 22
Re: Limits of CNC Mount Cutting/Etching/Bevel etc
Welcome to the Forum, Seb!
Is that SAS design this one? http://theframersforum.com/viewtopic.ph ... 53&p=53363
IPFraming
Post by IPFraming »
Yes, that is the one.
I was looking at getting something laser etched into the mount.
http://www.cutlasercut.com/services/pap ... ng-etching
Other than above, the people I have so far spoken with have use a Wizard 9000, but seems it cannot cope with this level of detail.
Hence my wanting to see what are the limits and whether I am looking in the right places.
Seb
Belinda Sheppard
Inner Piece Framing
Tel: 07806 56 33 22
GeoSpectrum
Post by GeoSpectrum »
None CMCs on the market will cut to the degree of precision of that laser cut if that is what you are after. But then again you can't cut mounts with a laser cutter. Well you can but the edges of the board get burnt in the process. I've investigated both.
benjiman grapes
Organisation: GN Framing
Interests: I'm a philosophical tea drinking film geek gamer with OCD. My family is established in Norfolk, England prior to 1686 and I butter with a spoon.
Post by benjiman grapes »
Hey there,
The SAS piece you speak of is David Wilkie's piece.
Has been a source of inspiration for many I'd say. Myself included.
Many questions.
What size are you looking at? The CMC blades can only do so much! But if you know how work the machine's software you can get more out of them.
Also what CMC you using? A 90 degree cut opens up many doors the 45 can't.
Looking at the motif you want, the wings, anchor and surround can be achieved but a much simplified crown would be required.
Benjiman
Benjiman Grapes
DURUM PATIENTIA FRANCO
| www.benjiman.co.uk | benjiman.grapes@hotmail.co.uk |
David
Post by David »
Hi Seb
The main limiting factors are you can't do fine detail or tight curves and the cost in time and mount board. The Navy motif has too much detail with the crown, leaves and rope, unless you are doing it 5-600mm wide, or you are going to simplify it a great deal to a simple crown outline. You can do fine detail with debossing and pen tool but this can cause further problems if your tolerances are tight. Personally I don't think it is a design that lends itself to being cut from board, I'd be looking to mount an actual badge if I wanted to include it on a mount design or do it with the pen tool as a drawing. I do some fine detail by hand but you don't want to be doing too much of that.
The other factor is the time, I use a Gunnar and you can create a design relatively quickly, getting the machine to cut it cleanly is another matter, it can take time fine tuning the design, machine settings and test cuts. The more complex the design with different angles and curves the longer it takes.
I've looked at a lot of military badges and the majority are not suitable.
David.
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
Using Pen Tool on Valiani
John GCF
IPFraming
Post by IPFraming »
Thanks all for your very useful comments and replies. Now much clearer. :D
Belinda Sheppard
Inner Piece Framing
Tel: 07806 56 33 22
