Pneumatic underpinner
muffinski
Organisation: none
Interests: framing
Post by muffinski »
Just been looking through some of the posts about pneumatic underpinners for recommendations, however, a lot of the models recommended are no longer available such as alpha minigraf 4. I am just wondering if anyone has recently purchased one of the newer models.
Whitewater Gallery
Interests: Surfing, sailing
Re: Pneumatic underpinner
Post by Whitewater Gallery »
I use an XL2 version of this one currently advertised on this Forum
http://theframersforum.com/viewtopic.php?f=7&t=14027
The jaws drop down leaving a flat surface to slide the moulding in and out which is brilliant particularly with large frames. That option is something like £500 extra but well worth it in my view.
I have no experience with other pneumatic machines but apart from a gripe about a couple of plastic parts, which can be replaced easily should they break, I would would be surprised if this machine would disappoint unless you are into production framing.
GeoSpectrum
Post by GeoSpectrum »
I bought a Casese CS20 Cart about 8months ago and I'm very happy with it. It my first air underpinner and I'm getting very good results.
muffinski
Organisation: none
Interests: framing
Post by muffinski »
Alan what compressor do you use? have you found any limitations with regards to molding size you can underpin?
Post by Graysalchemy »
That cassese 199 is an excellent machine, you will easily run it off a twin pot bambi though a single pot my struggle, you need about 6 bar for an underpinner, though it's the reserve and flow which is equally important especially if you are pinning multiple frames in quick succession.
muffinski
Organisation: none
Interests: framing
Post by muffinski »
Thanks Grays for reply Unfortunately cassese 199 is no longer available to buy new from what I can gather.
Its not but the example which is advertised on the forum looks in good condition. Cassese are very well made machines and should last a long time, my 3099 is probably 9 yrs old now and going very well. I am not quite sure which is the new equivalent model from cassese is. I wouldn't have a problem buying a second hand 199 they don't have any electrics in them (unlike the 3099) and seem very robust.
kevin
Organisation: picture framing services
Interests: framing, photography, table tennis
Post by kevin »
I had a cassese 199 for 8 years. Recently I purchased a cassese cs200. It is a very good machine and I would say it is an update of the 199.
