Canvas Stretching Machines For Sale
Posted: Tue 15 Mar, 2016 3:27 pm
by philm
2 Gapp Canvas Stretching machines (Canvas Stretch Master Production 1.2m x 1.2m)
Ideal for stretching canvas with less effort and in higher volumes! With one of these machines you can stretch two sides at once and can easily complete a canvas in a minute or two. They have been used but are very clean. They will stretch up to a 50" square canvas.
* Air operated so just need a basic compressor to run them
* Use on any stretcher bar depth - I had them set up to use 2 with 18mm bars and 2 with 38mm bars - quickly go between depths though if using just one machine
* Massive increase in production speed
* Just need a compressor and air stapler
* No more cutting excess away from corners - nice tight stretch ensures corners are nice and flat!
* Excellent condition
Some Videos Showing the same Stretcher Machines in Use:
https://www.youtube.com/watch?v=WPHoLM5jMbU
https://www.youtube.com/watch?v=kVXBQ44abN0
https://www.youtube.com/watch?v=QZnEaGJNdV8
See more info here: http://www.canvasmaster.net/products.html
Personally, I think the best setup is to have one machine set up for 18mm bars and one for 38mm bars and do both the landscape and portrait stretching on one machine. At an OK pace I find I can make 10 per hour on one machine including trimming the excess canvas off the back and taping the backs of the canvas - so the whole stretching process. If you had one machine it would only take a minute or two (max) to change the settings from 18mm > 38mm (or any other frame depth)
Another way to use them is to set them up in pairs, using one machine for the portrait side & one for the landscape side which is said to increase the speed and apparently with the right operator & depending on the size you are supposed to be able to produce 150 - 300 finished canvas per pair per day.
These machines brand new cost £7000 each. I am looking for around £2500 for the pair (no VAT), or will sell individually also. I have four of these machines. I am scaling things down here due to a long term illness that keeps getting in the way of my work, but I plan on keeping 2 for the future as I like them so much, in case I get the chance to spend more time on my business again and increase my order volumes!
Due to the size of these machines they need to be picked up by the buyer. I am based in Melton Mowbray (Leics) LE13 1NA
Please message me if you want any more info
Thanks!
Phil
You can see all four machines in the images below. Two can be fixed back to back as seen or one can go against a wall
Re: Canvas Stretching Machines For Sale
Posted: Wed 16 Mar, 2016 8:59 am
by Graysalchemy
Nice machines I can see why you operate them in pairs. Unfortunately I no longer do any canvases.
Posted: Wed 16 Mar, 2016 3:44 pm
by Whitewater Gallery
HI Phil, pretty sure I can not fit one in - but just incase what is the footprint/height for a single machine?
Nick
Posted: Wed 16 Mar, 2016 4:05 pm
by philm
Hi Nick
I'm at home now but will be at work in the morning and will measure up for you :)
Phil
Posted: Wed 16 Mar, 2016 4:06 pm
by philm
Graysalchemy wrote:Nice machines I can see why you operate them in pairs. Unfortunately I no longer do any canvases.
They are very good - even for someone who doesn't do a large volume they're well worth having as they make it so much easier and faster
Posted: Wed 16 Mar, 2016 8:03 pm
by Graysalchemy
Unfortunately I don't do any canvases now but 5-6 yrs ago I would have snapped your hand off.
Posted: Thu 17 Mar, 2016 10:35 pm
by philm
Whitewater Gallery wrote:HI Phil, pretty sure I can not fit one in - but just incase what is the footprint/height for a single machine?
Nick
Hi Nick
Apologies for the delay. I have measured them up today and one of them would require the following space:
Length: 80"
Width: 26"
Height: 75"
And then you'd probably want a gap of around 20" or so between the machine and your bench to work in
I hope this helps
Cheers!
Phil
Posted: Fri 25 Mar, 2016 1:41 am
by samsphotolab
I would be delighted to buy one - I assume the frame for a single would bolt to the wall. £1250 for a single?
David
Posted: Sat 26 Mar, 2016 4:02 pm
Phil
Thanks for the dimensions, unfortunately its close but I don't think I can get one to fit. Will just have to hope the tennis elbows hold out!
Good luck with the sale
Nick
Posted: Wed 30 Mar, 2016 10:45 am
by froggy
Are these machines still for sale?
Steff
Posted: Thu 31 Mar, 2016 1:56 pm
by philm
Just to confirm these are now SOLD
Three out of four sold and I'm going to keep one for myself :)
Thanks all for your interest!
