Removing grease stains from mountboard
Share your CMC experiences.
Or seek help and advice
Mary Lever
Post by Mary Lever »
I have a small grease/oil stain on a mount. I was told I could remove it using an iron, brown paper and lime juice. Does anyone know how much and how one should apply the lime juice? Or does anyone have an effective way of removing an oil/grease spot? Thanks,
Jamesnkr
Re: Removing grease stains from mountboard
Post by Jamesnkr »
Putting brown paper over the stain and then using an iron on it may work.
Lime juice, though is a 'traditional' invisible ink, developed by heating it. Surely the lime juice will leave you with a brown splodge instead?
Time to experiment, I'd have thought...
StevenG
Post by StevenG »
Have you tried a few applications of lighter fluid?
Unless it can be removed quickly and/or unless the mount has a fillet, deep bevel/whatever attached or is hand decorated, I'd toss it and cut another one, but in those cases I have had success with clean water, brushed with a progressively dry brush and also with extra fine (like 240 grit) paper - as long as it's an off white board, in fact the water method, or any liquid method can be bad on coloured boards, can leave a tidemark.
Post by Graysalchemy »
I would bin it and start again it's not worth the time and effort compared to the cost of a sheet of Mount board.
Yeahbutnobut, what if it's washlined and edged with real gold leaf!
Well if that was the case I would have priced in for wastage anyway so it woukd be no different to a standard xheet. I think if you start trying to bodge in imperfection or error you are doing your customer a disservice, they are not paying for mistakes or imperfections.
Material wastage is factored in anyway - but not really on something that is priced pretty much on time alone and I'd be looking at complete and fast removal with no trace or toss it anyway - not a bodge.
Even the simple plain mount is worth a quick go at before writing it off.
Hali
Organisation: Crafty Hangouts
Interests: picture framing and book reading
Post by Hali »
Regarding the method you mentioned using an iron, brown paper, and lime juice, I'm not familiar with that specific technique. However, I can offer some general advice and a great informative content for removing oil and grease stains .
One common method is to use a dish soap solution. Mix a small amount of dish soap (about a teaspoon) with warm water to create a sudsy solution. Then, using a clean cloth or sponge, gently dab the solution onto the stain. Blot the area with a clean, damp cloth to rinse away the soap solution and stain.
Another option is to use a solvent like rubbing alcohol or white vinegar. Apply a small amount of the solvent to a clean cloth and gently blot the stain. Repeat as needed, then rinse with warm water and blot dry. and you guys can read info here https://www.bikethesites.com/how-to-get ... f-clothes/
For particularly stubborn stains, you might try using a grease-cutting product like Goo Gone or WD-40. Apply a small amount to the stain and let it sit for a few minutes, then gently blot away the stain with a clean cloth.
Wow that's an old post that you've resurrected Hali!
I just have to say that WD40 is reserved for equipment in my shop (and rarely then). It's use will instantly wipe out any Conservation/acid free qualities of the mountboard and leave you with an offgassing issue. The simplest solution if possible, is to cut another mount with a slightly larger window and create a double mount hiding the offence.
Post by JKX »
RoboFramer’s advice is spot on to get the spot off :-)
Hali
Post by Hali »
Al right, Thanks for letting me know about the potential issues with using WD-40 on a mountboard. I had no idea it could affect the conservation and acid-free properties of the board. That's definitely good to keep in mind for future reference.
