Trusty Fletcher 1000 oval and circular mount and glass cutter cuts from 65mm to 520mm. Complete with instruction manual, spare blades and glass cutting wheel.
Gives you a capability for oval mounts without the expense of a CMC!!!
£150
FOR SALE Fletcher 1000 Oval Mount and Glass Cutter
- Organisation: School House Art & Framing
- Interests: Picture Framing
- Fletcher 1000.jpg (44 KiB) Viewed 7169 times
- John Ranes II, CPF, GCF
Re: FOR SALE Fletcher 1000 Oval Mount and Glass Cutter
For those that might be engineering oriented, this is a tremendously accurate machine and a great value. If you do not own a CMC....jump on this!
All the major manual manufacturers have dropped their oval mount cutters - Fletcher-Terry, Keen-Cut, C&H, Valiani... but this was the only manual machine where the blade TRACKED during the cut staying perfectly tangent to the center of the Oval producing results equal or better than a CMC. This is fact.
The pictures BTW look like the machine is in excellent condition for this machine. The F-1000 was upgraded to the F-1100 (virtually identical).
John
John
430 E Northland Ave
Appleton, WI 54911-2127 USA
Member: FATG & PPFA
The Frame Workshop
430 E Northland Ave
Member: FATG & PPFA
The Frame Workshop
Thanks for the input John
Kim
Kim
- Organisation: Folly framing
Hi, i would be really interested in this if it is still available? Do you know if you can still get the glass wheels and cutting blades? Would i be able to come and see it? Thanks
Hi , Have about 2/3 box of blades and assume that the cutting wheels are available readily although I haven't needed to replace it. Yes you can see and have a quick demonstration although we are some distance away from you. Give me a call on 01547 540593
Hi. Afraid I have lost my voice so unable to call! I will be travelling back down the m5 on Sunday afternoon and wondered if I could stop by if you would be around. Thanks
Now gone to a new home!!
