hi all.
real novice here!
we currently use a standard foot operated morso mitre. Looking to make the process more simple and to get a better result, i have the chance to buy a casesse 939 can anyone tell me the benefits of upgrading to this machine please?
thanks in advance!
Morso vs cassese double mitre
242framer
- Organisation: none as yet!
- Interests: framing, football, family!
Timh
Re: Morso vs cassese double mitre
we made that choice a while ago
best thing we ever did
242framer
Timh wrote:we made that choice a while ago
that's encouraging!
- Framerpicture
I would highly recommend the 939- If you have the space and good dust extraction you won't regret it
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Mitre saw
Pro's:
Larger cut capacity
Less effort
Better quality mitres
Cons:
Larger size
Noisy
Dust extractor required
Higher cost of servicing
(may also require 3 phase power supply)
your compressor may need upgrading
Mark
Pro's:
Larger cut capacity
Less effort
Cons:
Larger size
Noisy
Mark
misterdiy
- Organisation: Decormount
Plus you will have problems cutting fillets and small stuff, so you will probably end up keeping the morso as well
- IFGL
Also the 939 is much heavier, it's about a 5 or 6 times heavier in fact, if you should drop it on your big toe it will smart a bit.
I think they weigh around 750kg. You'll need a forklift to unload it and unless you have a big door
it's going to be a struggle getting it where you want it.
It will pay dividends though if you cut a lot of wide mouldings. It will also cope better on moulding with
undercut backs.
undercut backs.
