Large Drying Rack - 50 Shelf Spring Loaded
philm
Organisation: CanvasCrew.co.uk
Interests: Football, family, work!
Post by philm »
Spring loaded drying rack 160cm wide x 107cm deep. The height is 160cm when all shelves are down
There are 50 enameled shelves. Oversized sheets will fit OK as they can overhang - the only points of contact are the corner mounted 'feet' on each shelf.
It is on wheels so can be easily moved. It can also be easily dismantled to fit through a normal sized doorway.
I make canvas prints and have been using it for drying my prints after spraying them with varnish. I'm downsizing my premises and won't have room for it in my new location which is a bit gutting as it's really handy!! The white stuff that you can see on it is just the varnish that has settled on them and will just wipe off fine. It is in very good condition, only having seen light use!
Located in Melton Mowbray - about 15 miles between Nottingham/Leicester.
Looking for £180. Private message me if interested. Thanks for looking!
Phil
Photo 14-02-2017, 10 44 59.jpg (1.16 MiB) Viewed 1609 times
Photo 14-02-2017, 10 46 12.jpg (1.17 MiB) Viewed 1609 times
Photo 14-02-2017, 10 50 35.jpg (1.45 MiB) Viewed 1609 times
Photo 14-02-2017, 10 51 45.jpg (1.97 MiB) Viewed 1609 times
